4202 intake
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
You are majorly effecting power squeezing it down to 4" on the intake. It will spool quicker and run alot harder when that is fixed. Also the rubber adapter on the front of the charger will suck it self closed furter restricting flow. That will need to be updated when the engine comes down.Other then that is looks nice.
If you need help let me know...
Dan
I agree that necking down to 4" is not the greatest, but I highly doubt that rubber will suck itself closed - it is the same stuff that SuperDiesel and I used to make our intakes, you could probably stand on it without it flattening all the way.
I have a 5.5" inlet on my S475's race cover, I used a 5.5" to 6" elbow on the turbo with 6" intake piping.
68skylark455
Larry the "Stroker"
Aug 7, 2008
1,091
Texas
www.larrysperformancepalace.com
Dan
If we go to twins we won't need to worry about it:happy2:
It has worked great so far, no issues.
juddski88
Freedom Diesel
Jul 1, 2008
4,658
128
Chesterfield, Mass.
i use 5" McMaster vent hose, the thick blue stuff, and it is 'flexible" but doesnt move at all. not sure on how well it flows comapred to smooth-bore, since it is like an expanded rigid slinky, but i can't see my S64x needing enough air from it that it would restrict it, the K&N on the end of it is open and i run a ram air hood, IAT's on the highway are pretty cool:cool:
