4094AVNT Warning!!!
D-MAX Mafia
Hood down, smoke up!
Nov 4, 2009
1,112
13
Phoenix
The extra tabs must be for clocking the compressor housing when used in a different setup?. Thats the only guess I have.
I was pretty upset since it all could have been avoided if I had been told about it. Its over now and I'm just happy its running good. I was getting tired of driving it in manual mode just to keep the boost up and the smoke to a minimum!
I'm interested to know how Ken likes using the 4094AVNT in a twin kit and the other turbo he's running.
dmaxlover
Mar 17, 2007
453
WI
Nevermind the hole, that's a cheap and relatively easy fix... I'd be worried about where the missing piece is.
Gasuout
Johnny
Mar 20, 2008
2,188
Santa Ana , Ca.
Hopefully blown out from the pressure ....
Ya I thought about this too seeing the picture of the hole .... picturing small aluminum pieces jammed in the top of the pistons or stuck down the side of piston in ring glands .
Not cool !! ... or something I would want to be picturing on my motor .
D-MAX Mafia
Nov 4, 2009
1,112
13
Phoenix
Relatively easy?! Hahahahahaha! You obviously haven't had to do this before! The new lower intake manifold only cost me $60 though.
The motor ate the piece of aluminum. I'm not extremely concerned about it, my 2011 D-MAX will be here soon.
13,765
834
Ben, Ken used the 4094vvt in a twin set-up but I am not sure what the low psi turbo was.
If you're talking about Subman and his truck Whiteout, I'm almost positive the 4094 he used is a fixed geometry turbo.
dmaxlover
Mar 17, 2007
453
WI
Yes, relatively easy! Why, would fixing or replacing the entire engine be easier? Or how about the hundreds of hours you'd have to work to pay somebody to fix it.
ripmf666
15,123
14
47
Wentzville Mo
Sorry about your luck. I have sold a few of these turbo and to tell you the truth did not know of a issue with the tab and the guys taht have ran them and are running the did not run into this issue. I told Dan @ PPE about your thread he said call him he would talk to you about any issues you have.
Tyler@MPF
Oct 28, 2008
55
Are you sure? He got with me several months ago and ask about how I liked the 4094vvt.
D-MAX Mafia
Nov 4, 2009
1,112
13
Phoenix
The bottom end characteristics of the 4094AVNT should make a great turbo to twin with. Tyler, do you have any plans to add a twin to your truck any time soon?
ripmf666
15,123
14
47
Wentzville Mo
http://www.duramaxdiesels.com/forum/attachment.php?attachmentid=15069&d=1277936496
10 sec street truck. (10.89 @ 129mph at DA of 9000 ft) 2006 EC/SB LBZ. 4x4. 86,000 miles, approximately 400 miles on the engine. Totally built, complete with roll bar good to 10.0 sec. Maintained stock interior but jump seat in rear is out to accommodate roll bar. I have the back seat. Truck is all white, including bumper, roll pan door handles, mirrors and grill. Black Tonneau cover and a gray cloth interior
Full built LBZ engine including:
TTS rods
TTS custom cut cast pistons
TTS extreme race cam
SoCal Stage 2 heads
SoCal Dampener
PPE dual fuelers
FASS 260gpm lift pump
TTS Billet fuel pickup
Big Dipper 130% over injectors
MPI Twin Turbos 4094 over a 5533
Spearco intercooler
MPI custom up pipes
BD manifold
MBRP turbo back 5" exhaust
SunCoast Stage 5 tranny
SunCoast 1053 Torque Converter
Yukon Grizzly Locker
QA1 double adjustable shocks front and rear
CalTracks
Di Pricol Optix gauges, boost, drive pressure, EGT, fuel pressure, rail pressure
mounted MT drag radials and Street tires
Twin Flex-a- Lite Electric Fans
Tuning by Adrenaline Truck Performance
DPS5 switch 700-1000 RWHP depending on the tune selected.
I have over 60K in this truck I'll sell it for $40,000 firm.
Tyler@MPF
Oct 28, 2008
55
It is in the cards, but not until I decide to tear the engine down and do it all. I am not quite ready to pop it yet.:D
D-MAX Mafia
Nov 4, 2009
1,112
13
Phoenix
I hear ya on that. I should be on Team Borrowed Time! I need a trans and probably about due for a tear down on the motor! I'm looking at a new long block to go in so I can build up the motor that I pull out. I'm on the fence though, I would really like a 2011D-MAX and I already got the "OK" from the misses! I change my mind every other day! Maybe I'll just let it all go for a 2011 TransAm! Those are sick!
ripmf666
15,123
14
47
Wentzville Mo
:spit: I always love this part. I never ask I just come home with what I want :rofl:
flyinelvis11
543
50
VG, IL (because my wife does)
i say 2011 t/a but then again what do you expect from a guy who wears a "what would bandit do?" shirt and only if it comes with a bird on the hood! besides you could always find a cheaper/older dmax for a dd and make the t/a your "go to town" car:thumb:
D-MAX Mafia
Nov 4, 2009
1,112
13
Phoenix
It does have the Phoenix on the hood! Check out Phoenix T/A (not sure the exact website). They are sick!
Maybe I'll hit the Powerball and buy them both! Wishful thinking!
