$4000 Total Purse, $1,500 to WIN 2.6
ctdiesel99
Jul 10, 2012
24
Payout scale will be the following for the Sled Pull:
Workstock 1st $400, 2nd $200, 3rd $100, 4th $50, 5th $50
2.6 $1,500 for first, $750 for 2nd, $500 for 3rd, $250 4th, $100 5th, $50 6th, $50 7th
Open class will payback 100% of class entry fees.
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Sounds like a good time
That's pretty southern almost from what I hear "HICK" I would suggest Tony go mobile make a point to go down there and mend some fence and tune some pulling trucks for free! :joker: :joker: :joker:
ctdiesel99
Jul 10, 2012
24
:dontknow:
Payout scale for the pull will be the following:
dmax06
barely getting by......
May 10, 2009
262
white plains, GA
This event was held in December last year wasn't it? We went up to beans and pulled last year, but I thought it was in December
ctdiesel99
Jul 10, 2012
24
yeah last year it was in December.
We were shooting for October this year, but couldn't get the date nailed down with the sled operator.
This one will probably be one of the biggest events we've held!
ctdiesel99
Jul 10, 2012
24
Workstock Rules:
2012
BDP Work Stock Diesel Truck Rules
The Work Stock Diesel class is designed for daily driven on the road full bodied, four
wheel drive pickup trucks with a variety of performance upgrades. A valid DOT
registration and license plates are mandatory.
Weight: 8500 lb
Regulations:
Ballast:
Ballast is permitted. Ballast may be added to the bed of truck. Ballast must be securely
mounted in the bed. No weights permitted in the cab of truck. Front ballast must not
exceed 60 inches from the center of the front axle.
Batteries:
The Batteries must be securely mounted and in the factory location.
Body:
The body must be the OEM truck body including the full bed floor. The body must retain
full sheet metal. Metal aftermarket hoods are permitted. No fiberglass hoods. The hood
shall be closed and securely latched while the truck is hooked to the sled. The complete
OEM firewall and complete OEM floor pan is mandatory. A factory installed pickup bed
or commercial aftermarket flatbed must be installed.
Brakes:
Four wheel hydraulic brakes are mandatory and functional.
Chassis:
The OEM chassis is mandatory. The engine must be in the OEM location for the body
used. The vehicle must retain the full OEM chassis. Wheel tubs, back half conversions,
tube chassis, etc, are prohibited.
Cooling System:
Radiators must be in stock location and be of at least stock size
Compressed Gases:
Use of any compressed gases is prohibited. (Nitrous or propane or any other)
Credentials:
All drivers must have a valid state driver’s license. Vehicle must have current registration
and current license plates. And proof of insurance may be required.
Driveline:
An OEM transmission and transfer case are mandatory. They must have been an option
on a one ton or smaller pickup.
Drive Shaft Loops:
Are not required but are highly recommended, and may be required by tech officials if
driveline damage occurs regularly. Recommended to be at least six inch wide u-joint
shields around the rear u-joint constructed of at least ¼ inch steel or 3/8 inch aluminum
that will safely contain the u-joint and the end of the rear shaft. All shields must be
securely mounted to the vehicle. Any front shaft u-joint that is visible from the side of the
truck must be shielded to contain the u-joint and the end of shaft.
Driver Restraint System:
The OEM restraint system is mandatory and must be worn.
Engine:
The engine is limited to a stock appearing, OEM compression engine, available from the
factory in a one ton or smaller truck.
Exhaust:
All vehicles must be equipped to direct exhaust upward. The exhaust must exit rearward
of the driver’s compartment. Stacks exiting through the hood or fender wells are
prohibited. If the muffler or catalytic converter have been changed from stock, two (2)
3/8 inch diameter bolts must be installed through exhaust pipe in a cross pattern within
one (1) inch of each other and as close to the turbo as practical. Bolt
heads welded to the pipe, or sheet metal screws to mimic this will be grounds for
disqualification.
Fire Extinguisher System:
A fire extinguisher system is permitted, it must be securely mounted All vehicles are
recommended to have at least a 2 ½ lb extinguisher with working gauge securely
mounted within drivers reach.
Fuel:
The fuel must be pump #1, #2 diesel, or Soy/Biodiesel. Off road fuel is prohibited. Must
be commercially available fuel.
Fuel Injection Pump:
The fuel injection pump is limited to stock appearing, OEM engine make-specific pump
only. The use of multiple high pressure common rail fuel pumps or HPOPs are
prohibited. Power stroke engines with a single turbo may utilize a second HPOP. Pumps
from different years in the same engine model may be interchanged. P pumped 24 valves
will be allowed. No Sigma or 12 cylinder pumps allowed. Must utilize a stock automotive
governor.
Harmonic Balancer:
All engines turning more than 4500 RPM must be equipped with a harmonic balancer or
dampener meeting SFI Spec 18.1.
Hitch:
The hitch must be a receiver style hitch, reinforcements are permitted. Reinforcements
must not extend forward of the center line of the rear axle. Trick hitches are prohibited.
Trick hitches will be determined by the Tech Official. The hooking point must be the
rear most point on the vehicle and must be rearward of the stock location of the tailgate.
The hitch must be horizontal to the ground and stationary in all directions. Bumper may
be notched or removed. The hitch’s height from the ground may not exceed 26 inches.
The hooking point must have a minimum of 3 inch by 3 ¾ inch inside opening for the
sled hook. The hooking point must be a minimum of 44 inches from the center of the rear
axle to the hooking point. The hooking point will be where the hook touches metal. That
is the hooking point.
Intercoolers: Only air to air intercoolers are allowed.
Interior:
A complete factory OEM interior, including dashboard, door panels, headliner, etc. is
mandatory. Aftermarket seats a permitted, they must be fully upholstered. All factory
controls, lights, windows, signals, wipers, etc, must be retained and in working order. The
uses of hand throttles are prohibited.
Rear End:
Non OEM rear-end housings are prohibited. The rear end housings must have been for a
one ton or smaller pickup pick up. Rear axle bolts must be covered by a cap or shield.
Steering:
The vehicle must retain the full, original OEM steering gear. The vehicle must retain the
original OEM power assistance, if it was so equipped. Additional stabilizers are
permitted. Non OEM power assist methods are prohibited.
Street Equipment:
Complete headlight and taillights assemblies (all) are mandatory and must be operative,
and must be installed during competition. Complete OEM windshield and all other
windows are mandatory. Windows must be able to operate per factory specifications;
they must open and close by electric or mechanical means.
Suspension - Front:
The factory suspension configuration must be retained. The upper mounting point for
strut assemblies must be in factory location. Adjustable caster/camber pillow ball mounts
are permitted. The lower control arm may be strengthened provided factory mounting
points are maintained. The lower mounting point for the strut assembly may be modified
for improved caster and camber. Strut tower braces, lower tie bars, sway bars, and limit
straps are permitted. Traction bars and devices are permitted. Final decisions rest with the
Battle of the Bluegrass Tech Department.
Suspension - Rear:
An OEM style suspension is mandatory. Traction bars and devices are permitted, they
must be bolted on only, welds are permitted for attachment to the frame or axle housing.
Traction bars if installed must have a chain or cable or some type of safety device
mounted one (1) foot from the front support to catch the bar in case of failure. All OEM
suspension mounting points must be retained and used. Sway bars, limit straps, and
camber kits are permitted. The rear suspension must maintain a minimum compression
shock travel of one inch. Compression stops may be adjustable. All rear suspension must
use at least one working shock absorber per wheel. Air bag spring assist is prohibited.
Tires:
The tires must be DOT street tires. 35 inch max. Cut tires are prohibited. No chains or
studs.
Transfer Case:
Non - OEM transfer cases are prohibited. It must have been an option on a one ton or
smaller pick up truck.
Transmission - Automatic:
Non - OEM transmissions are prohibited. Aftermarket torque converters, valve bodies
and internal components are permitted. Transmission brakes are prohibited. Any non -
OEM floor mounted automatic shifter must be equipped with a spring-loaded positive
reverse lockout device to prevent the shifter from accidentally being put into reverse. A
functional neutral safety switch is mandatory. Vehicle must not start in gear. All
transmission lines must be metallic or high pressure type hose. All vehicles with engines
running 4500 RPM or more and using an automatic transmission must be equipped with a
transmission shield meeting SFI Spec 4.1 and must be labeled accordingly. A blanket
type shield is permitted, It must be appropriately labeled as meeting SFI Spec 4.1 and it
must extend from the rear of the engine block to the front of the tail housing with a
minimum of six (6) inch overlap where it is fastened. All non-blanket shields must
incorporate two,(or one per manufactures instruction) ¾ inch by 1/8 inch straps that bolt
to the shield on each side and pass under the transmission pan unless the transmission pan
is labeled as meeting SFI Spec 4.1. All vehicles with engines running 4500 RPM or more
and using an automatic transmission must be equipped with a flex plate meeting SFI Spec
29.1 and be covered by a flex plate shield meeting SFI Spec 30.1.
Transmission - Manual:
Non - OEM transmissions are prohibited. A clutch meeting minimum SFI Spec1.1 or 2.1
is mandatory on all engines running 4500 RPM or more. All manual transmissions must
be clutch assisted. Sequential shifters are prohibited. All vehicles with engines running
4500 RPM or more and equipped with a manual transmission must have a flywheel shield
labeled as meeting minimum SFI Spec 6.3 or greater. Applications for which an SFI Spec
flywheel shield is not available may use a properly attached SFI 4.1 or 4.2 blankets that
completely cover the bell housing. It must be attached to the rear of the engine block and
extend rearward to the transmission with a minimum of six (6) inch overlap where it is
fastened. All transmissions or clutch pedals will have a safety interlock switch so that
vehicle will not start in gear.
Turbocharger:
The vehicle is limited to a stock un-modified, OEM/ Factory charger with factory
configuration only. Turbochargers from different years and different models may be
interchanged. You are allowed to take a hx35 off a Cummins and put on your Duramax
or vise versa, and you are allowed to put a Duramax turbo in your 82 Chevrolet with a 12
valve).Any vehicle may use up to the inlet size of a Duramax Turbocharger. The 6.4
power stroke engine may utilize the factory twin turbo configuration. The driver will be
responsible for making turbo accessible for tech personnel to measure and inspect. If you
have any questions regarding turbo rule contact Battle of the Bluegrass Technical
Department.
Water Injection:
Water injection is prohibited. All system components must be removed from truck.
Wheelbase:
The vehicle must retain the original factory wheel base and track width. Cab and chassis
trucks may not exceed 172 inches center to center of axles. Front dual-wheel spacers may
be used only with accompanying positive-offset dually style wheels.
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
Dot and registration? Congrats, you guys will have a bunch of workstock trucks for 2.6 trucks. Should be an awesome class. Btw a mandatory electric kill on electronic trucks is retarded. All trucks should have an air kill period. An electric kill at the back does nothing for blown turbos and a motor running off oil.
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
That's how it is with 2.6 out my way too. All 2.6 trucks have to be registered, insured, and street driven.
With hoodstacks? Lol street driven is good for workstock level. He said they want some of the hottest trucks on another forum. You won't have that with street 2.6 trucks.
ctdiesel99
Jul 10, 2012
24
Posted this on the other forum, i'll post it here too;
You're right, i could give a **** less if the truck or driver are licensed and registered.
What do you say we just forget the set rules, and do something like this:
2.6 charger same rules as above
Stock frame
No injectables
8000lb max
Trans out of 1 ton truck or less
Some safety rules
And the rest fly's
We just want everyone to be able to come pull and have a good time and not worry about passing tech except for the important stuff
What are your thoughts?
Harbin_22
3,858
7
Southern Indiana
I think that is a great idea on the reg. 2.6 is always like "hot street" or something to that nature. Yeah let me see you drive any of the top trucks to the grocery store. 2.6 is rediculous, it is way to big of a jump from work stock, to not even street legal trucks. IMO they have ruined sled pulling for the normal guy that really does have a "hot" street truck. Keep the rules, maybe make for a more even class, instead of the top 10 being trailer queens
ctdiesel99
Jul 10, 2012
24
Okay. Way too much confusion on the rules. I have deleted previous rule posts for the 2.6 class. Here is a link to the official rules for the 2.6 class.
They are basically 2.6 class rules from PPL with a couple of sections omitted. If anyone has any questions, or concerns feel free to contact me and I will answer them for you.
Again, we are trying to make it so all you guys can come and make a great end of the season pull, and take home some money at the same time.
http://bdpshop.com/blog/?p=485
ctdiesel99
Jul 10, 2012
24
Bump for those who have forgotten or haven't seen it, event is less than a month away.
I have also acquired over $1,000 to distribute for the dyno competition, and will hopefully raise that amount by the time the event rolls around.
ctdiesel99
Jul 10, 2012
24
We had an awesome event! Biggest turn out we've ever had, about 60 trucks on the dyno, 30 or so 2.6 trucks, 25 workstock trucks, and i think 8 unlimited/open class trucks. Something around the 1700 mark as far as spectators.
We are working on getting all of the results posted on our website, I will let everyone know once they are posted.
We just want to thank everyone that was able to make it, this event wouldn't be what it is without each and every one of you!
Already looking forward to making it bigger and better next year.
Stay tuned for results from the sled pull and dyno competition.
