i use a 8000 pound 4 post for now and it work pretty good but i geting ready to get rid of it to get a 2 post lift.
Do they make lifts that only raise a vehicle 3 or 4 feet?
I would like to put one in my garage, but I only have a 10' ceiling. I just need to lift it enough to change tires, do brakes, slide a tranny out from underneath etc.
just some food for thought there is some work you cant do on a drive on 4 post lift , i would go with a 2 post the options are unlimited on the work that can be performed, and they are usually cheaper, i like rotary , and have had good luck with Whip , on a four post you cant pull your rear end out and some front chassis work is hard depending on if you can find a spot to lift the front up and still have the parts clear to remove them , 4 posts are great for trans work , oil changes, tires, brakes but they have there limmits .
rotary does state 3000psi, 6" thick. Maybe 4" of 3500psi is equivilent?? Not sure, didnt mean to argue paul, I was just confused/worried because we recetnly poured a floor with the intent of adding a lift and only poured it 6" 3500psi.
The ones I was looking at, bend pak, and the lifts from Greg Smith Equipment all required 4" 3500psi.
We only have an 11' ceiling so Im going with one of the baseplate lifts. It only requires like 9' 8" clearance.
Not trying to argue either :hug:A 6" floor is more than enough. I was just trying to show what to do if someone doesn't have a thick enough floor and doesn't want to repour the whole thing.
I don't think 6" is enough lifting these trucks. I went 2 feet down with rebar. I use BendPack 12K lifts and was told to do it this way.
