4" lift on 33's
Iowa
Jan 17, 2015
So much SEXY in one post! WOW!!!!!
4" lift with 305/55/20s..I think the reg cabs sit higher or it seems that way
Great looking truck! Are those NFab nerf bars? I'm thinking about getting a set for mine!
coldLBZ
Apr 22, 2007
2,344
Alberta, Canada
Another question: Those with a Cognito 4" and 33's would you be able to measure how high your truck is? Like from the ground to the highest point on the roof, I need to see if my truck will fit in my garage with this lift. Thanks again.
Jesseh72
32
Avon Ohio
Old truck 04 w/Cognito 4-6 TBD rear has add a leaf and 1.5in block. 305 55 20 on 20x9 w/ 0 offset.
New truck 07.5 w/ Cognito NTB and 3in block in back. Same tires and rims 305 55 20 on 20x9 w/ 0 offset. I plan on narrower tire next time around. But its about perfect.
80.5-81 in is the height to the top of the antenna on lmm. Hope this helps I looked forever before I did the first truck with little luck. Any questions ask.
kivetts04dmax
May 20, 2010
742
Boonville, MO/Pendleton, CA
How big of a job was it to remove the lift and go back to stock? Thanks. :)
It's not a real big job, hardest part was with the diff ear fix, I had to drop my centerlink to get it past (Kryptonite) and once I got it in place it was hitting on the motor mount so I had to drop it back down and cut the bracket then it finally went, I will never lift another truck..
Stancedlb7
Cummin Stroke this Duramax
Feb 9, 2015
649
SLC, UTAH
If you haven't decided yet, I personally like 6" dropped to 4". 4" looks too much like a stock or leveled truck. With a wide offset 33" tires aren't too small with a 6" lift.
