4.3 V6 Turbo????
six5creed
1,046
58
N.C.
Anybody done a turbo on a 4.3 V6? I have a 1993 Sonoma I drive to work and run errands with etc. and been thinking about this to wake it up a little, how hard would it be to put a turbo on it?
SmokeShow
6,818
Lawrenceburg, KY
Wonder how compatible a setup off of a GN or Syclone/Typhoon would be? They're both turbo'd 4.3 V6 from the factory. :coolspot:
I wonder what those factory boosted applications did for the head gaskets? Isn't head gasket failure fairly common on 4.3? Adding boost sure wouldn't help that I wouldn't think.
Where's Johnboy when you need him?!?! He's probably forgotten more about turbo'ing the 4.3 than most of us will ever know - he played with the GN before he got into the duramax IIRC.
gmduramax
Shits broke
Jun 12, 2008
4,072
248
Nor cal
The syclone my dad has bent the rods at 22psi and never had head gasket issue. I do think it bent the rod from detonation though. Not sure what trans was in it but it was stock and ran 12.9
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,492
472
Central OH
The Buick wasn't a 4.3, but they may have some similarities. I always thought intake gaskets were the real problem, but I wouldn't be afraid to boost one.
ZeroGravity58
1,401
51
Maryland
I had a vortech supercharger on a 1992 4.3l S10. The biggest problem is the that is a CPI motor and I would think you'd run out of fuel. The one I did I switched to a carb. It was a stock shortblock and made 10psi, ran good but never had it on a Dyno. The stock 4.3 head flow like crap and the stock cams arnt much. The intake gasket issues we're on the later 4.3s where they switched to a plastic gasket. Felpro makes and replacement. GN is a 3.8l motor
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
The cpi would be your limiting factor. That single injector simply can't flow enough fuel. You could always pick up a 4.3l marine intake(looks like the 4.3l vortec, but is made of cast iron with external injectors), do an 0411 ecm swap easily enough, swap in a 4l60e from a 5.7l and build it, and then add some boost.
six5creed
1,046
58
N.C.
Thanks for all the suggestions and letdowns, lol. I now realize it’s just a daily driver and will probably stay the way it is until something major happens to it. I hope that’s a while, it’s a 1993 with 146k miles on it.
ZeroGravity58
1,401
51
Maryland
Put a racetronix fuel pump in it a buy a NX wet kit:D A 100 shot would be plenty fun
