I would really like to lower the rear of my truck without changing springs. Right know I use to of the 2" wide rachet straps. Works good but I would be nicer if I could just run without them. Anybody have an info on running them?
i have some on the truck they are 2-3" drop shackles from norcal nick. they have 2 holes to adjust for the extra inch. i have them at 2" drop with no issues
THESE are what I have on my truck. They have 2 sets of holes as well.
Im running the belltech 3" drop shackels. Easy to install but time consuming.
They take about 10 min a side. My buddy pulled with 3 inch drop shackles and it kinda screwed him. I wouldn't go more than two inches. Plus the belltech 3" actually lower it about 5 in the rear
may i ask what the theory is behind lowering the rear for pulling? where's the gain?
Did you measure before and after trent? I made some shackles that the holes were 4.5" farther apart than the stock shackle and it lowered it the exact same amount as my buddies truck who had the 3" belltechs.
At the axle, mine lowered me about 3". The gate is about 5" lower. Lowering the gate was my main reason for installing the shackles.
The only problem has been the reduction in rear axle travel. You will hit the bump stops a lot more after the lowering. In my case, I hit the air bags a lot. It makes for a hard hit too.
