3.73 gears and 35s
jmbcary44
Jul 20, 2011
86
FT Drum NY
Ok, so as I am just easing myself into this field I have some questions. As per the VIN check I found out I am running 3.73 gears with locker and my truck is on 35s with a 6 inch lift.
After doing some readign I see alot of talk about going to 4.10...is this advised?
I have no experience with gearing and the truck came with the lift. I put the 35s on.
I just got my VIN check so if I need to put more info up just let me know.
I am just looking for someone to explain this area to me even though I know it is broad in scope.
Thanks
jmbcary44
Jul 20, 2011
86
FT Drum NY
thanks for the quick response, I am trying to get stuff together and fixed before I had the truck over for a year to the family.
S Phinney
4,008
Quncy, Fl
Only time I would change would be if I had the six speed and a larger turbo. They are about perfect with the five speed tranny.
Sent from my SCH-I500 using Tapatalk
jmbcary44
Jul 20, 2011
86
FT Drum NY
cool, I think I will be keeping them then! any advice on changing the gear oil in the diff before I move 800 miles? figured it would be a good idea.
darkness
1,317
380
vegas
what are your plans for the truck? i pull heavy (and in the mountains) and the 4.10's were a welcome mod after the 35's. but it was a cheaper decision for me because im 2wd :). my next set of tires will be 33's and back to stock gears. thats when i got the best mileage from my truck.
jmbcary44
Jul 20, 2011
86
FT Drum NY
I mainly was just curious to see what recommendations I would get. Mine is a daily driver, not to many mountains up here. I only have an 800 mile move to NC and back befroe deployment and then it is going back to the family for a year in NC. So I guess 3.73 should be fine.:thumb:
D-MAX Mafia
Hood down, smoke up!
Nov 4, 2009
1,112
13
Phoenix
I always say regear especially on a 6 speed alli. I can still do 130 mph with the 4.56 gears which is fast enough to go to jail. Just my $.02
5,835
Let me know if you wanna sell those 4.10s rob. I need a rear set :D
DieselS10
May 12, 2009
97
Oklahoma
Slightly different animal, but my old man has been running 37's with 3.54's on his 12 valve Dodge for about a decade with zero issues.
22 highway mpg and will effortlessly pull whatever you hook to it.
dmaxvaz
wannabe puller
Nov 22, 2006
1,132
46
METRO DETROIT
you cant relate this to a 12 valve cummins, those make tq lower in the rpm and will be fine with taller tires (likes to be lugged at low rpm. A duramax with 35s sucks for towing unless you tow in 4th gear at 70mph or tow at ,80+mph, because you fall under the charger and bogs when you are pulling up hills. 4.10s or 4.56s will be better to tow with and egts will be lower; it will a little more rpm/air flowing through the engine. I have had 3 sets of 35s and a 6" lift with stock gearing, and really sucked for towing or pulling hills with a decent size load. Take it for what its worth.
