factory gears always setup the best imho but ive never had much issue with Yukons. i just setup a set of used yukon 5.13 gears for my ford 8.8 going from stock 3.73. only needed .004 more pinion depth and off set the ring gear to the driver side .0012 from factory shims. pattern is dead nuts center and great depth into the tooth. to get a used gear to setup like that is hard to come by.
