I got into a bit of a back and forth with this guy on his Youtube channel that I thought I would share with people here. I have been in aircraft and vehicle maintenance all my life, most of that as a field tech rep for a major aircraft manufacturer. Durance and reliability is everything to me. I personally had high hope for the new 3.0 Duramax. If I ever had to replace my trusted LMM this might be a way for me to go. When the engine first came out I was shocked to see they put a wet belt in the back of the engine to drive the oil pump. This pump belt has a life limit to it. What?! This is a brand new from the ground up new engine design. This Youtube guy has interviewed the chief engineer on this engine a few times. The first interview he basically stated that "it is what it is'" and moved on. On the attached link at about the 19 minute mark the guy on the video states that the engineer stated that the reason they went to the belt was because of reaching a minimal noise level that would be noticed in the interior. OK, now I will throw the BS flag on this. You already have chain drives for the cams in the back of the engine, you could not have driven the oil pump with a chain? Yes straight gears will make noise but most beveled gears make very little noise. Practically few engines have induced a life limit on a component with the oil pump, it makes no sense to do one now on a clean sheet designed engine, let alone one that requires the transmission to be removed to access it.
I understand that most owners who purchase this engine new likely will never see the life limit of this belt. The original limit was 150,000 miles. The newer 3.0 has it now at 200,000 miles or 15 years. I go back to my original statement, why induce a maintenance action where none had been required before? If this was to correct an issue on a existing design is one thing. To make it this way on a clean sheet design is another. I hold onto vehicles a long time. I purchased my LMM in 2009 and currently have 215,000 miles on it. I have incorporated a number of mods that will increase the reliability of that diesel engine. It is exceptionally clean and in peak running order and I plan to keep it that way. As long as I don't get into a wreck it could easily be my last truck. It does not even see salt since I used my wife's old Subaru as a work car these days. I know a number of owners of this engine are very happy with it, it does get great mileage but it will not be for me. I also think they made the cooling system way to complicated for what it needs to be. Just my honest opinion. Dean
Source: https://www.youtube.com/watch?v=vx-thbPvxvw&t=1229s
