LB7: 2WD RCLB Street Toy
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
I think having a professional build a tune will make a big difference. What actual issues are you having? For me shift point tuning made a night and day difference.
The biggest issue is getting the charger to light. I think shift points would help but it takes quite a bit to get the turbo to fully light. I am starting to mess with the timing tables more to see if that doesn't help.
PACougar
2,105
41
El Dorado Hills, Ca
Have you pressure checked everything and made sure there aren't any exhaust leaks? I realize this is the "have you plugged the power cord in?" question but someone had to ask:) shift points really do make a monster difference for a big single.
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
I did a boost pressure test and got all leaks figured out on that side of things. I haven't touched the exhaust manifolds since removing the engine from my pulling truck so I wouldn't think it would be those but I will double check everything. From what I remember the engine compartment is pretty clean still.
I might try tow/haul to see if that helps out some before messing with the shift tables. :thumb:
