So I recently did a full delete and tune on my 2015.5 LML. I installed the DSP 5 switch at the same time of tune, instantly got a PO193 FRP code. Getting a DFRP of 5656.56 and actual FRP of 31908.8. These numbers do not change on scan tool, even if sensor is unplugged! Have it eliminated down to DSP 5 Selector switch is wired wrong or ECM is junk. Does anyone know which pins the switch should be wired in for the 2015.5 LML? The instructions from my tuner say to wire to:
2011-2016 LML: Gray ECM connector J3
Pin # 11 & pin # 35
Every other thing I can find online say the switch should go to 27 and 46 for this year LML.......wondering if this might be cause a malfunction in the ECM if the tuner's instruction are indeed wrong?
Please help as of right now I am $550 in the hole from trouble shooting plus hors of shop time! Have tried getting a new tune file sent and re-flashed. Bought a clean factory tune back to verify the ECM, changed FRP sensor ect. Tested wires, jumpered to get low fuel reading on scan tool from ECM and pressures stayed at a fixed reading.
Thanks Ryan
Pin # 11 & pin # 35
Thanks Ryan
