Does anyone have a pitman arm puller that works on the newer chassis?
How I do all of them. It helps to have a half worn down wheel for the last little bit by the box. Usually one good brap from the air hammer in the cut and off it falls.I use a cut off wheel, cut a notch almost to the shaft. Then take a chisel and split it and it falls off.
Saves pulling the box down. Takes about 30 min total.
Doesn’t answer your question, but it’s functiona, time saving and free.
As in this one? https://shop.snapon.com/product/Pitman-Arm-Pullers/Heavy-Duty-Pitman-Arm-Puller/PAR1188i have the snap on one thats $300 , used it once when i didnt have a cut off helping a friend lift his truck.
but i too usually slice the old one down near the taper . falls right off with the heat from an abrasive cut off.
