LBZ: 2007 classic lbz build
Yngdmax92
962
Just installed Danville 3794 stg2 with customer vanes and down loaded his tune in, at the same time, did the dhd pump rub, and did pressure mods, mike l trim springs, white shift valve springs and a Georend DK converter. All I can say is omg! Thing is ridiculous.
I previously had a lb7 with a mps 63.5 modded stocker and built trans, this thing is way way way better then that. It's like it never stops pulling. Converter couples so hard it's unreal! I literally melt the tire on a roll dig from 15 mph or so. Defiantly need to build the front end as a 4 wheel drive launch with no boost gets very scary.
Only complaint i have is the 2nd to 3rd shift has a very high flare some times. Maybe it's because of the new added power or maybe cause the converter is trying to lock and it's shifting at the same time, but I squaked the tires in 4 wheel drive whne it landed in third. It'll flare up to 4000rpm or so.
All in all, wicked good setup! 35lbs of boost. Thing is aaaaa singing!
