Reset it so it defuels when the water temp hits 240*shim the fprv, also set the defuel level on the mini max to a higher temp.
If "fprv" stands for fuel pressure relieve valve, then there's already a PPE race valve (plug) installed.
Where are you guys installing fuel pressure gauges after the lift pump?
Looks like I'll be making a trip to see a mechanic soon.
No clue on the fuel temp when it goes into limp mode. Doesn't matter how long I drive when the trailer is hooked up.
I called up the company who builds the lift pump and talked to a tech. He told me I'd be fine running with what it comes preset at. I, think, that was 8psi. I'd have to look it up again.
