2005 lly power extend mirrors and I replace with lbz mirrors
andrew1703
Jan 31, 2014
Hey new the the site new to diesels aswell. 2005 lly 2500 SLT 5 inch mbrp, egr delete, little efi live run thru cts. Basically hate these power extend mirrors for towing would like the newer style tow mirror is it possible
jc1843
Sep 27, 2009
228
87
So Calf
The ones sold on the internet are a good copy of the GM ones-- and a lot cheaper. I have one of each and hard to see the difference.:D
Taylor-34
Jan 13, 2014
443
Cali..
Just splice them together then? Find out which one is you constant power, defrost and module controls and dead end the wire that is your power out power in
werewolf
Apr 27, 2012
118
eastern Noth Carolina
Do you have the power, Heat, turn signal on yours now. Either way just search eBay or amazon and find the tow mirrors for your model. They come in with power, heat, turn signal or other combinations. You can double check your plugs now but I'm pretty sure yours are the two connector type. The tow mirrors will bolt directly on and plug in only thing you will lack is the extending part. Everything else works the same. Also, I have heard memory functions for the mirror get a little wacky if you have that function
hopkins_fam
Oct 18, 2013
91
Will the power extend option still work if my LLY has the factory power extend? I too want 06+ mirrors, or is it easier to get power everything w/ manual extend?
ALLY Fox
Old Man Truck
Dec 14, 2010
434
Oregon 7S5
I've never had any issues with my accordian style tow mirrors but I wouldn't want to have 'em if I lived in a cold climate, they look like they would be nothing but problems in snow and ice. Biggest problem is, my dogs like to stand on the armrest switches and either knock the adjustment out of whack or extend them so I have to watch when I pull into my garage. Dogs have locked me out of my truck a few times too, I've learned NEVER to leave the keys in or leave it running with the dogs inside!!
werewolf
Apr 27, 2012
118
The large tow double style mirrors DO NOT power extend or power fold at all. You have to do that manually, the only thing that is power on them is the top glass, turn signal if you have that, and heat if you have that. The mirrors are plug and play across the board. There is a change in the harness where I believe it goes from one plug to two. Double check yours but I think it's the two.
andrew1703
Jan 31, 2014
Ok thank you that's what I was wondering if they could be replaced
