Is there anyway to test if the FICM is bad? Did an injector install and #7 injector is still showing bad. Could a bad FICM be the cause?
What would a new one cost?
history of the engine? estimated hp? how high is the balance rate?
have you done return rate tests on the suspected injectors?
You should do a compression test.
I have new FICM's for $200
Think if you might have tightened one of the #7 injector wire nuts to tight and the wire swung around far enough to touch the valve cover? Get a schematic for the 01 FICM and see if #7 wire connections are shorted to ground, should unplug ECM connections also.
