Just out of curiosity did you ever experience a "bump "when coming to a quick stop and it doesn't downshift to first until you are stopped ? I think these two things go hand-in-hand my best guess is some seat time and changing that internal filter like you did are the best bets but what do I know I'm just a keyboard warrior
Don't mean to kidnap the post, but Its funny Ive been experiencing the exact same symptoms as described here, especially the bump....almost as if someone tapped you from behind. I'm getting the "neutral" feeling too just as it shifts down from 2nd to 1st, and it almost neutral drops if you get on it too quick.Couple times it felt as if it was a standard, and the clutch isn't pushed in when coming to a stop. Today it got bad, which is why I'm on here btw. On my way to work, I stopped at the store and when I put it in reverse, it smashed into gear real hard and loud, and instantly the engine light lit up, It felt as tho it was in 2nd gear going backwards....and then when I put it in drive, it smashed into gear, and suckholed away....stuck in second gear.I limped it to work 4 blocks away and parked it. Came out just now and it is kinda normal, but the engine light is on. Now it feels funny taking off but does shift. I assume it went to limp mode. Not sure where to start. First trans issue. 01 LB7 stock, 285,000 KM's. Any help appreciated.
