2-Stroke Oil as a fuel additive???
ChevyTruckGuy78
Twins done Now for trans
Feb 7, 2010
694
Ct.
not saying a word on the outlet thing but I gotta tell ya the smell my finger thing had me laughing my a$$ off. Dude thats funny!!
i wired a whole door bell system useing telephone wire 24 volt doorbell button and 24 volt buzzer boy what an experience all in my bedroom talk about trouble
If I'm wrong someone will be sure to call me out on this but my wild ass guess would be that by removing the sulfer from the fuel thay also removed the lubrisity (good with the bad i guess) It's not so much the sulfer loss but the lubrisity loss. Thats what I'm after...
jon5212
Oct 13, 2010
119
I had read using ATF in a common rail is not good since ATF has detergent properties. I use about half to one full quart of 2 stroke oil per fill up.
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
It's pretty much the same when the took the lead out of gasoline. Now there is the problem with Ethanol.
I really didn't realize so many where running 2-stroke oil. I'm going to have to try it and see what it does for my lop. Maybe it is the low sulfur causing my FPCV to be sticky. I always run more additive than recommended but maybe it isn't doing the job.
D-MAX Mafia
Hood down, smoke up!
Nov 4, 2009
1,112
13
Phoenix
ATF does have detergent properties but it also lubricates like a champ. Think of all the moving parts and wear parts in a transmission and ATF is all that keeps it moving. I like it because it helps keep the fuel system clean and also lubricates the pump and injectors.
booxr800
Boo
Sep 13, 2009
157
Central Michigan
I was surprised about Marvels doing so bad in the testing. Actually showing negative results. I always thought it was good stuff, well it is just not as an additive.
Colt
Jul 23, 2010
523
well I gotta say I am nothing but happy with the 2 stroke oil so far. No joke!! runs smoother, starts better, better mileage - so far, even shuts down smoother? Go figure.
These are all things I've realized and just know it's so smooth and quiet from listening real close to it run and shut down like you say too. I let it idle a few minutes to cool the turbo down also but that's just a habit from way back just cool any engine down after a workout thing a debateable subject each user choose your way to treat the motor.
KryPTiC
Recovering Diesel Addict
Oct 3, 2010
Flying down Alberta roads
I run atf in my unit... never touched the lb7 injection yet, 400,000kms (owned it since 40,000). Did balance test the other day and all still good, so I guess it doesn't hurt.
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Is it a miracle? Power of suggestion? You want it to work and or make changes? I don't know but I did top off my tank yesterday and added 2-stroke oil myself and I'll let you know what I find out. :D
Noreaster
2,910
Cape Cod,MA
I add a quart a fill up, Coastal is the cheapest I can find around here & I use up the leftover quiksilver & yamalube from boating season
mb1
149
Edmonton, Alberta
+1 here on walmart 2 stroke oil. Look for the TCW-3 rating is what I read somewhere.
I run 200 : 1 when I have some handy and I think about it. Thats a liter in my 52 gal tank.
I thought I read that ATF resists burning and that makes it undesirable in fuel. IDK.
