2 sizes of U-Joints?
WanaDmaxsub
Junior Member W/gray hair
Feb 17, 2007
644
I don't think this pertains to Pat's question...but did GM have some issues with 2 piece drive shafts and had to replace several of them???
RoadRashRon
Feb 15, 2012
17
I have an 02 CCSB with 1 piece aluminum drive shaft. I replaced the rear u joint about 2500 miles ago and now there is play in the retaining straps. the retaining straps were not changed. I didn't notice the play when it was installed. I'm asking because I need to replace my yoke because there is a groove worn in the seal surface on the yoke sleeve and it wont stop leaking. Can you install a 1480 yoke in a truck that had a 1410 from the factory or do you need to change the drive shaft as well?
thanks
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
I don't understand it either, my truck, a 2002 gmc ccsb has a two piece steel drive line yet my buddy who has a 2002 gmc ccsb, the same damn truck has a one piece aluminum. And by the way damn I hate my two piece.
Old thread I know but that is the first I heard of a CCSB having a two piece drive shaft. I was under the impression or assumption that the two piece drive shafts were used on the CCLB. Everyone else either got the Light Pole or One Piece Steel.
MOST CCSB I've seen have the Alum (Light pole) drive shaft. There was no rhyme to reason on this subject figured out who got what. For the record I have the Alum shaft in my ECLB dually.
Darius6t9
I'm the Floater. Lurking.
Aug 23, 2008
574
Rusk, Tx. Again
I have a CCSB and it has a 2 piece. But mine is also a 2wd. I was under the impression that any of the ccsb or longer trucks 2wd's had the 2 piece. The 4wd ccsb had either one, but the longer trucks most definitely had a 2 piece. But that is just what I understood from a discussion I remember on DP a few years back.
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
2 wheel 4 wheel might play into it but the guy I quoted appears to have a 4x4. So again makes no sense when they are on both configurations. I recall the discussion on the DP and it was never figured out if I recall there either.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Anyone have a vin number from a truck that came with 1480 U-Joints? It makes it a lot easier when ordering parts from the GM dealer. Thanks.
messejme
Jazzy, Me and Max
Mar 7, 2008
741
Branchburg NJ
Maybe the additional weight of the steel 1 piece required a better spec than the light alum 1 piece or the very heavy 2 piece with the third bearing (carrier).
