Building a street legel pulling truck would it be worth buying a different turbo because 2.5 is the limit or should we just keep the stock one on a 07 LBZ were hoping to make close to 600 horse with water meth is this possible with the stock turbo
a GT4088 is a 2.5 legal turbo... that would be a great option
how much boost will it make and what would be a good injecter to go with it
We can run water meth and a 2.5 turbo only thing we cant run is nitrous no limit on money this guys family is loaded, and I know the stock turbo will make 32lbs of boost I dont think 8 more will help that much will it, and what horse injecter would you run he has a FASS 150 lift pump
An S400 based charger with a 2.5" inducer would be the way to go. Significantly cheaper than a GT4088 as well. And done right would give you the option to bump up to 2.8 or 3.0" once you got a built motor, for the cost of a new cover.
X100. The GT40 series are lame. You would be much happier with a nice S400. Have a cover made to make it 2.5 legal.
Bigger tires would be better unless your only puling on VERY tight tracks.
These guys are speaking the troof!
GT4088 is a very good charger and has been proven on the track time and again. Although, you could have a fully custom S400, totally duded out trick charger that would be legal for the price of the GT40.
I'll get Ecc in here, he pulled with the 4088 for 2 seasons. He just changed to a forced inductions custom and says it is miles ahead of the Garrett.
