Built my Allison in my LBZ this spring, along with twins, mild motor build, etc. The build consisted of suncoast raybestos clutches in c2-c4 and alto carbonites in the c1, mikeL pressure spring with no shim, mikeL shift & trim valve springs, & an ML-G converter. The trans shifts AMAZING at full throttle. The only problem I seem to have with it is a 200or so rpm flare on light throttle 2-3 shift. ECM tunes are by Kory & and tcm tune is stock except Tcc tables for slip.
