1st time at the track
05maxlly
need used tires
Jan 27, 2008
194
powhatan, va
wow what fun i am looking at my times compared to others listed in the time slip list and i am wondering what i am doing wrong or are yall racing way lighter trucks i was thinking and hoping with my upgrades that my times would be better what do i need to do. i dont want to be in the 12s but a low 13 would be nice. my turbo is still stock and you can read my sig to see the rest here are the times
60-2.119
1/8-9.285
1/8mph- 76.79
1/4-14.387
1/4mph 96.59
my truck is heavy like 7400lbs i guess its all the leather i dont know but if i am doing good and should shut up and be happy let me know
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Congrats on your first time :D
What tires are you running? You need to drop those 60ft times a little.
maddogg101920
I break stuff
Mar 2, 2007
733
CECIL COUNTY, MD
hmm.....my truck has the full package leather and all, truck weighed 7100# with full tank the other day, ran in the 12s on 1/2 tank so whats that 6800-6900#, plus i run 33" tires so its not that, how much boost are you leaving with and how much RPM?
RPM Motorsports
smokinum
May 13, 2008
3,271
10
Central Valley Ca.
Drop the tire PSi, Clamp the rear springs, drop the front, 10lb boosted launch should get you atleast in the 1.8 60' range. It's all in the launch. I drop the tire psi lower then most would dare, & she hooks like glue!
13,716
779
You definitly need to drop those 60' times. Your MPH is good enough for high 13s, but your losing time on the launch.
Here's what I do when I race. I run about 30 psi in the front tires and 26 in the back, drop the front until the axles are just barely pointing up, and launch at about 2000-2100 RPM with about 15 lbs of boost. I consistently cut high 1.6 to low 1.7 60' times on a set of 265 A/T type tires.
MAXLLY
No Lemming Here
Aug 15, 2007
1,063
San Diego
remove the spare tire and tailgate, drop some air out of the tires, give it time to boost up, 6-8 lbs boost isn't enough if you are that heavy. Dually huh?
Your truck might not like to be "pinned" as soon as you leave, try a little lighter (80-90%) throttle as you leave the hole, feel it. If it gets worse go back the other way.
As boost comes up and you hit it harder and harder, the launch is gonna change... you may "hop" a little, the springs may wrap and give you a "WTF was that?"
It's a blast (addiction) enjoy the seat time, experiment and log, log, log. When you hit OD take a look in the passenger mirror, are you smoking hard?
Just stuff to look at for tuning reference later on.
Later
05maxlly
need used tires
Jan 27, 2008
194
powhatan, va
i am clamped and my torsion bars are droped prettly low i did have 80psi in the rears and 65psi in fronts so that alone my be the whole problem i dont have a boost guage so i dont know my psi it seems to be smoking well all the way down the track i took video of the runs but can get them off the camcorder to post them :( o well. on my second run i broke my suncoast so i got to pull it out tonight and get it on a pallet and ship it down to them hoping of a fast turn around, also would like to know what gave
the truck is a ccsb single wheel and weights that much
