Having a weird issue with 1st gear and half way into second gear being very laggy and something is keeping it from fueling properly.
I know it is not a tuning issue because I got my new dual fueler tunes tuesday morning and the truck ran great. Parked the truck tuesday night and didn't drive it till Friday when I was heading to the track to race and that is when I noticed the lag. We flashed my old tunes in last night and it still does it. Didn't have time to mess with anything so I raced and dynoed the truck anyways...it fuels normal and everything if your already in second gear or higher. Also if you can get the boost up enough while doing a 4 wheel launch it seems to fuel fine as well.
When you mash the pedal from a dead stop it would take right off, shift to 2nd and blow the tires right off. Now with the lag if you mash it from a dead stop it takes right off and at about 8 psi of boost the power just falls off, makes it to 12 psi, shifts to 2nd gear and half way through second gear the power just kicks in full boar and the tires blow off and truck takes right off.
Few things I've done so far....cleaned maf, pulled intake and check turbo..it spins freely, balance rates are ok...#5 cylinder was a +10 Friday for some reason..its been a +5 since the day i bought it 2.5 years ago and has not change except for friday. Check again last night and it was right back to its "normal" +5.
What should I be logging to look for?
