1st and 2nd gear delete
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Start in second, let it shift to 3rd. Raise RPM enough to to pull past 300ft still in 3rd, hammer down. lol.
LMM 4low tables needed to cure that crazy defuel issue was resolve back around 2009.
:driving:
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
Change of plans, won't be pulling this weekend as the weather isn't looking promising and it's too much work to go from drag racing till midnight to sled pulling the next day.
durallymax
Apr 26, 2008
2,756
Under The Hood
I quit building boost after having to sink another $500 into my front end after this hook. Just went to punching it outta the hole, it'll come to life eventually. I ran a 1055 Torque converter and an S472 charger with less than optimized tuning (my own). Rev limit was set to 4500 or so IIRC.
[YOUTUBE]1uUr_-UUfHE[/YOUTUBE]
After that ordeal I just started punching it, you can see in the video below that the charger still spooled fine until it bit the dust during the last hook in the video. The 5yr reunion for my truck not running is coming up.
[YOUTUBE]L4aI7s83D-Y[/YOUTUBE]
Woody87
58
Mt. Vernon, IN
When I pulled stock motor, rev limiter was set at like 5500 :thumb: I watched heat more than boost. I had a 2nd gear start with a 1058 converter. I would slowly apply throttle until egts reached around 1200* then floor it while letting off brakes. If I can find a video of it from 2011 ill post it. BTW I ran 4k+ all the way down the track with no problems at all and never broke any parts from leaving the line. Torsion bolts all the way out with 2" solid blocks in the factory bump stop location.
Found a video, fast forward to around 30 seconds for the pull.
http://www.youtube.com/watch?v=4C_7YA1ZRDY
My06duramax
Mar 16, 2013
17
I've always rolled out and had good luck with it. A stock charger will light pretty quick. The track has a lot to do with it to. If it's a rough starting line you don't want to get the truck hoping
