160 mpa at idle
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
2 lb7 cp3s both modded = Actual 145mpa, desired = 35mpa
Unplug PPE and nothing changes.ground is good and 10 amp keyed power is good
Unlug stock cp3 and it goes to 160 mpa
plug in just the stock cp3 and it goes to 160 mpa
Tapped on both regulators and nothing changed?
WHAT ELSE CAN I TRY?
Is there a fuse for the stock cp3?
Im going to try some new regulators but they worked fine last year
JOHNBOY
< Rocking the Big Single!
Aug 30, 2006
2,159
Saegertown, Pa
What happens if you plug the stock location pump in to the stock plug and take the belt off? Just try it for a minute. If it idles like it should either you have a regulator stuck on the second pump or a toasted PPE driver. If it still idles with high pressure you stock location pump regulator is toast.
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
I tried that but didnt remove belt....Does the belt need removal?
JOHNBOY
Aug 30, 2006
2,159
Saegertown, Pa
YES
That worked im now at 35ish mpa
Then the next I would do is swap the regualtor on the second pump (if you have a spare) and hook it all back up. If it works like it should the it was the regulator. If it goes high again then the controller is the issue.
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
So swapping regulators on the PPE with a known good one would be the next step?
To eleiminate the controller?
Thanks for all the advice people:)
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
You took the word right out of my mouth:D
JOHNBOY
Aug 30, 2006
2,159
Saegertown, Pa
I'd swap regulator first as its easy to do.
That is what he is doing.
Going back to one pump is very easy for test purposes. Instead of blaming parts and just swaping. Your far better off to trouble shot and eliminate what is not causing the problem.;)
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
The belt is a PITA on my truck, thats why I think swapping the reg. is easier, maybe not for some. Chances are is it sounds like a regulator more like a regulator anyway. I just went thru all this a few months back...I also had a good regulator sitting here. For what its worth though...I had a WD regulator go bad on the 2nd pump and a controller go bad....( the controller was intermittent though.)
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
Seem like it was the regulator unless the controller is doing something internintent
Now I cant log Abby:rolleyes: Connects and gives the notorious scambled VIN# wont log rail pressure.
LBZrcks
Jun 2, 2007
5,297
12
SoCal
How up to date is your V2? maybe you can just standalone log it, I think rail pressure is a preloaded pid in the LB7 pid list
