So truck is far from stock so I’m sure it’s not the factory issue. Problem started when I re geared truck 3:73 to 4:30. Truck is on 37’s originally had bfg km3 on it well road forced them twice no fix. Had new driveline built no fix so I bought new tires road forced no fix. It’s a high speed vibration about 63-72ish. I can power through with no vibration. Also coasting through that speed with motor slowing truck down no vibration. But if I’m coasting in that speed range and give it slightly any throttle it vibrates. So I don’t think it is tires or drive line. Any ideas on what it could be I’ve heard of fuel surging with tuning? It is ppei tunes. I’m assuming it’s something speed related or rpm rated since it started after gearing. Also has a hard clunk when I lock the brakes up and let off them like a kick in the ass. Thought maybe slip yoke but not it lubed it up still there. Also doesn’t do that at high way speeds or when I take off only braking really hard and letting ass sit back down. Both started around same time. I thought maybe trans mount? Don’t see how that would vibrate
