12v cummins
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
Got a bud buying a 12v reg cab 4x4 5spd. I'm excited about his build. He used to have one, says it was a beast and missed it ever sense he bought his CR 5.9.
He is a very knowledgeable diesel tech, being around them for quite a while. Should be a decent little build.
Going to be a little competition in the air! I'm going to need twins!
08 LMM Chevy CCSB
Relentless Diesel trans
JoshH EfiLive tuning
554hp 1014ft-lbs 7/30/11
coker6303
Aug 6, 2009
2,484
40
Houston, TX
I'll take either...just can't be one up'd!
08 LMM Chevy CCSB
SmokeShow
6,818
Lawrenceburg, KY
As long as you're racing from a stop, his chances aren't very good unless he gets absolutely nutty with power. How many 11sec trucks are there rowing gears? Not many! Now how many D/A are there in the 11s? Several. :D
coker6303
Aug 6, 2009
2,484
40
Houston, TX
Thats what I was thinking too. He claimed his old one was stupid fast, and beat a lot of 12sec trucks but he was also a teenager at the time and we all know how stories from the past can get stretched.
If I can hit the 600hp mark he will have to have a ton of power to row gears and keep up (pending I keep mine together). He's going to be running a big single.
I have a feeling its going to be more big talk than anything. He knows his stuff for sure, no doubt about that. But I think he'll be more conservative than he is talking.
Either way, it's going to be a nice truck and should be a strong runner!
13,712
772
Most super badass fast 12 valves that I've seen around these parts run in the 13s and 14s. Not saying they can't make power and be fast, but most of the rednecks around here driving those trucks just turn up the pump and think it's fast because it smokes out everything in it's path. Also, not saying that's how your friend is, but what I'm saying is it takes more that just a little tweaking on the pump to make power with those trucks. It isn't as easy as some of the Cummins guys make it out to be.
darkside
Sep 15, 2011
21
left coast
They are a fun to play with. They can get up and boogie with fairly minor tweeking. I had one for many yrs. Just sold it to buy a max. I miss the cummins already, but Im liking the chevy too.
5,808
08 LMM Chevy CCSB
you will be fine, hes gunna need injecotrs, delivery valves, time to tune his fuel plate, change his timing to 18*+, headstuds, a big turbo (atleast s366 which is BIG for cummins guys unlike us), a good p-pump, probably have to ditch the factory lift pump too for a bigger one, and some other crap im forgetting just to keep up with you. And thats if all is working as it should! I would not worry at all. my buddy had all of the above minus delivery valves and used a s364. he made a whopping 450hp on the dyno and with jsut a tune, lift pump, built trans and exhaust i could pull him on the freeway. His truck was on 35s and is a ex/lb compared to mine too :D
coker6303
Aug 6, 2009
2,484
40
Houston, TX
In most cases you are absolutely correct! But this guy will be doing everything right. He will not be just sliding or installing a fuel plate and calling it quits. Found out he is going to be running a S3xx series single for now (pulling the one off his common rail).
He is a very smart guy, very mechanical minded. I trust him with any of my stuff, he's like a brother. I know this is going to be a nasty truck! I'm probably as excited as he is about the purchase!! going to check it out at his house tonight when he gets back.
I already told him I'm going to put a hood stack on it after he goes to bed...or at least cut the hole for one so he has to!! lol
SmokeShow
6,818
Lawrenceburg, KY
Yeah, I wasn't dogging the ol dinosaur. ;) I too had a 12 valve once & it was a lot of fun. Miss it some days just because of the good memories I had in that truck.
coker6303
Aug 6, 2009
2,484
40
Houston, TX
Sounds like its time to step it up a notch.
I wondered when you would chime in! I need a sponsor...you and Eric look like sponsor material! Lol
08 LMM Chevy CCSB
13,712
772
It definitely sounds like he's going all the way with it. I wasn't saying your buddy was the typical Cummins owner. I was just saying the way some Cummins guys talk, you just turn a few screws and get 500 HP. Like James said, he'll need delivery valves, injectors, bigger turbo, possibly need to have the pump benched depending on how old it is, etc. Definitely not like some guys make it out to be. You have to remember, those motors are at most, 215 HP stock. That's a long way to go to get 500. You go from stock to 350, and it feels like a massive increase (which it is) but still nowhere near a Duramax with even just tune that is safe for the stock transmission.
What year cummins just curious not that it matters. You can some preety cheap twins if u have some fab skills. Least ur friend lucked out as far as price on parts. Everything on those 12v are cheap turbos injectors, no worries on bending a rod;)
coker6303
Aug 6, 2009
2,484
40
Houston, TX
It's a 95 which I believe has the 180 pump like the autos. He will be changing delivery valves, rack travel, timing, etc. I don't know much about it but hope to learn a little during his project.
It's pretty rough on the exterior so he will be putting some body work in. It was an old farm truck that the farmer bought new in 95. Hard life!
08 LMM Chevy CCSB
madmatt
Apr 12, 2009
1,595
"the mecca"
www.facebook.com
A customers truck went 536 on a s362, a small cam, ground plate, afc mods and other pump tweaks, 22* timing, 4K springs, 100hp sticks and stock delivery valves,,,,,, pretty gravy up too 500-550 really.
5,808
ah yes, ive heard cams make a difference for those bigger chargers on the cummins. must help out that choked up head
gr8shot
Practically stock
Apr 28, 2009
262
3
Grand Island, NE
Its pretty fun to see what can be done with just simple hand tools, ill admit that. My 12v went from a complete dog to at least able to get out of its own way with about 45 mins of pump play. And that was my first time taking one apart. Is it a speed demon? No far from it. But its definitely fun to see the direct correlation and instant results from the tweeks you make.
Other than that, mines a freaking pig. Obnoxiously loud, both the engine and exhaust, leaks out of just about every place possible, its a pain to start when its cold, and did I mention how noisy it is? But I do like it, and I love the instant throttle response of a mechanical motor versus the computer controlled fueling on the dmax.
Sent from my Droid using Tapatalk
mikeholmen
Sep 8, 2011
Airdrie, alberta
08 LMM Chevy CCSB
Probably a 175HP pump. Get the part # off the side of pump so you can find out for sure. We have several tweaked stock truck near 500rwhp. First off you'll parts are dirt cheap and power easy to be found. Best mod going is to throw in 4k gsk, SDX competion delivery valves, rack the barrells, and throw away the fueling plate. Tweak the AFC for full fueling. What clutch is in the truck, most 12v's we have use a 3600 SBC dual disk, just cause you'll make tons of power.
