LB7: 12sec turbo ??
Ryan T
1,007
CA
U can do it, there is a red dodge dually that was popular a few years back that ran 10s , it was in diesel power mag a couple of times.. Adeso has gone 11.70s lifted on 37s, im sure it can be done
6,080
my truck easily hits 12s with the stock twins with where it is now, should be high 11s now. before i blew it up, it hit 13.04 with a weak launch and a badly draining rail.
6,080
The spray will bring it down a little, other than that 1/4mi EGT is not a huge issue unless you're blowing past 2k. If that's the case revise the timing in the tuning.
Sent from my iPhone.
The drivepressure would have killed your head gaskets muuuuuuch sooner lol
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
If you're running a 10 I would hope you are not on stock headstuds :eek:
T4 S366 use the same turbine side setup as my 472...I dont see DP a huge issue.
