108.5 mph in the 1/4
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
the other problem i see is the bowl design. and the need to open them up like guy does. I didnt crack a piston ether i put a hole in one within direct corolation with a injector hole. I def agree cooler egts will help but not the answer. I want to see wht the out come of mats motor is if its a hole or a crack or somehing else
So do I buddy, so do I. :rolleyes:
Thinking I can get it down to Guys this weekend. Crap I STILL need to call him.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Your MPH should have been a ~12.40 run. You did not state if you boosted up at launch. That would make a big difference in ET.
IMO, the meth did what Pat said...it burned hotter, so you lost the piston. In the meantime, you were making a lot more power than you thought. Curious if you ever dyno'd that tune while using your meth setup.
depends on the track and many things i trap at 108.## and have got as high as 108.9 but have never ran past a 12.70 due to traction issues , torque converter issues , and some hanging shifts all of wich have been solved but no runs since, so it can happen .
