1058 With 475 Single Issue
Ne-max
I like turtles
Nov 15, 2011
3,361
64
Lincoln, Ne
Have any of you guys ran into any issues with a Suncoast 1058 and a single s475/87/.90r? I am having issues trying to get mine to do a boosted launch. I can only get it to 6psi and 1800rpms. Then it is just a smokey mess. It did this with stock fueling and now the exact same thing with bigger injectors and cp3. I thought the 1058 would stall to 2300?
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
That's exactly how my 72/87/1.0 was with my 1055. It spooled ok on the stock motor/compression. Went to 16:1 with the new motor and could not get the 1055 to stall at all. Went to a 1053 and it lights the turbos like a boss.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Stall speed doesn't mean it will instantly stall to its rated rpm.
How hard does the truck fuel when trying to stage? May need to scale the maf back a hair so it doesn't choke the motor.
DetailsUnlimited
1,264
Benton, Ar
I have a 2100 stall and had this issue. It was the T4 gasket leaking on the back side where I couldn't see it. Not saying it's your issue but it's a start.
Ne-max
I like turtles
Nov 15, 2011
3,361
64
Lincoln, Ne
I recently went from a 83 to a 87 and I inspected all of it while it was apart. I did the same thing with the 83. I thought it was just no enough fuel
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
I had a suncoast 1057 which is a low stall and could spool my 475 pretty good. You definitely have to have the tuning right to start off with. If I held the brake and just went into the throttle it would just go into a dead bog. I got my best results by easing in with about 1000 RPM's, I'd hold there until my egts got to 800 or so then feed it some more. I could get it up to 2500 or so and cut some 1.7 60' .
PACougar
2,105
41
El Dorado Hills, Ca
I've ran a 475 and now a 480 with a 1058, regardless of the tuning, it won't stall high for staging. Now it couples and drives great, just no burnout on slicks.
S Phinney
4,008
Quncy, Fl
It is a tuning issue unless there is a problem with the convertor itself. I personally wouldn't run less than a 1055 with a turbo that large. Have you tried bumping into it instead of just holding the breaks and pressing the pedal. What is your throttle limited injection at ?
PACougar
2,105
41
El Dorado Hills, Ca
I've personally ran three different tuners tuning. I can do a burnout no problem on street tires, just not on slicks. I can get them to start spinning but it's just a hair too low of RPM to really get the charger lit. It also likes to push through the brakes at a relatively low amount of boost. As I said, street driving is great with the 1058.
