Well no more ATS. im in the works on odering a sc 4 any suggestions on a converter for my sig ? in thinking a 1054
How much tighter is a 1054 than a 1057? I would like to switch out my 1057, it seems too loose all across the board. My truck spools pretty darn quick and seems to blow through the converter even under modest acceleration.
[/COLOR]
meening it doesnt lock ? or you blow through the brakes while staging ? just trying to help , some 1057's seem tight and others seem loose for some reason .
No, meaning that when I roll into the throttle it seems that the engine rpm, boost, and power shoot up quick, but the converter feels like it is slipping pretty bad and doesn't do a good job transfering power through when unlocked.meening it doesnt lock ?
Doesn't blow through the brakes while staging. i definately have one of the loose modelsor you blow through the brakes while staging ? just trying to help , some 1057's seem tight and others seem loose for some reason .
I have a special converter for twin turbo set ups that works very well. Kinda like a 1054.
I do not like the 1054, way to tight even with the small twins on an lly, Im probally gonna have to swap it out now, as im in the process of putting a silverbullet on the truck in place of the twins!
