GMC_2002_Dmax
The Still Master
What I have found is that overfueling a dmax makes for better power at WOT as long as rail psi is held.
Ed Wayne and I spent a lot of time with his truck at the track and we bantered back and forth whether or not the extra fuel was necessary.
In the end more was better.
My advice is to let your SOTP meter and the track times dictate your pulse width choice, don't use an arbitrary number.
Also the psi drop is greater the bigger you go because when the injector opens you lose a lot of psi at the nozzle, it may seem wrong that you have to add pulse width at lower psi/mm3 but it is usually the case.
I looked up the tune file for a twinned LLY I tuned in Canada with SoCal 100% sticks, the pw ranges from 1860us to 2470us on the smaller tunes, the bigger tunes have 2800-3100us and it may or may not be overfueled, but it sure does run.........:thumb:, also with two completely stock LBZ pumps there is no problem maintaining 26K+ rail psi.
I would suggest starting at 1800-2000us at WOT and see how it does.
Good Luck
Good Luck
