running toyo proxes. What was your 60 ft. On your 10.70 run?
Vids were cool , get somre tires and you should pick up more than just in the 60 , Your launches were way soft and you should be able to pick up a few 10ths any way .
My 60's were 1.62, 1.64, 1.64, and 1.67. do you think drag radials would help that much.
What are you calling "stock internals"? I don't want to start an argument here, but there isn't a whole lot more you can do to the internals to beef it up. The only possible upgrade would be forged pistons, but I haven't seen where they're all that much more reliable than a good set of cut and coated stock pistons. As far as I know, no one is changing the crank unless they are doing a stroker motor, and things like heads and cam won't increase the strength. They will only increase the efficiency or change the power band. Maybe I'm way off base, but I'm not following what you're saying.This is more power than anyone can expect for the stock internals.
Even if it didnt improve you 60 ft , if you were able to leave harder and be on top of the chargers more your 1/8 mile ET is going to improve , you already have the MPH , but need to get the 1/8 mile ET into the 6's . What RPM were you launching at maybe it just "looked " low ?
I think all bob is saying is it's a pretty basic build. We put modified pistons, rods, balanced it and put it back together. I have however done what I can to keep rpm low (tall tires and 3.42 gears) and timing and duration down by going with the bigger injectors. There may come a day when I regret not doing heads, main studs and some of the other things people do. When I did the motor I figured 11.5 was it. but we all know how that goes.
Sounds like that converter is hooped to me.
Simon's 55 locks like a dream. Or maybe he doesn't have enough power to slip the converter yet.
Have heard of others saying the 1055 and 1058 doesn't like to lock early. Mike L might be able to give me his take. didn't Simon put in one of Braydens lockup controllers. I wouldn't care as much if my drive pressure and egt's didn't go so high before lockup.
Shawn landed up flying down to Redding to drive Randy Cole's dodge to qualify for Boise. Here's the slip. I was by myself so no video. turns out the slip doesn't want to attach. anyone want to resize it.
Breakdown
1.67 60 ft. /had a best on the night of 1.62
7.13@101.5 in the 1/8th / best on the night was 7.03 but not a big enough tune on the top end.
10.96@128.5
