1/4 mile discussion and time slips post here!
Noreaster
2,910
Cape Cod,MA
Buck made it to the track on sunday, ran into some map problems due to the great air, so put an old tune in the truck. ran a single pass, 9.24 at 151.6. crappy 60 ft, weak trap prep just test and tune, so loaded it up and went home.
:thumb: Nice to see a 1/4mile run, Ive seen some videos of some damn quick 1/8th runs from this year & last
J Spruill
bringer of truth
Mar 30, 2008
770
the 60 ft was a 1.59 and the back half split was 1.52 . if it short tracks like it should... looking low 8.8s
Subman
Old Geezer
Jun 27, 2008
3,233
80
Madras, OR, Pahrump NV
I'll update the list Jess thanks and congratulations to you guys.:thumb: Can you give me the updated info like weight and is it still a LB7? Still running a duraflite correct?
J Spruill
bringer of truth
Mar 30, 2008
770
im not sure on weight, we talked about that at Rudys race hoping they had a scale set up but it rained out. last time we scaled truck was in the 5900 range but it has been a while since it was done. pretty much what has been cut out lately gets more weight added back than took out. Still TTS tuning, lb7 and Duraflite.
Subman
Old Geezer
Jun 27, 2008
3,233
80
OK I'll use 5900, it is running triples now so that is more weight. I'll update after this weekend as I know there are a couple of trucks trying to get higher on the list this weekend with the cool fall air in Boise.
Noreaster
2,910
Cape Cod,MA
Ken, you should probably add this truck to the list
Wade Minter bought Spooner's old truck, he's pretty local to Ennis (I forget exactly where). Very friendly guy and pretty open about his trucks. He had the RCLB at Ennis in April and had just finished putting it together (it was white then), he was having trouble trying to get it to spool and ran a fastest of 10.4X or so. Came back for Finals and had Spooner's truck too and wrapped them both to match. He clicked off a 9.4X in his RCLB on one pass.
obviously need some info on it
DURAMXD
BOB SAGET!
Apr 24, 2012
348
Wichita, KS
It's 33 on the list right now, just needs updated. I didn't get a video of the 9 second pass at World Finals though. :mad:
Not sure if he is on the forum or not. It just got added to the list by Ken after his first pass in April at Ennis when it ran the 10.44.
Subman
Old Geezer
Jun 27, 2008
3,233
80
Yes I knew it went pretty fast in it's last pass at Enis but 1320 go didn't record the world finals for some reason. I have an email into Brian trying to get the correct info. Pretty sure Brian's old truck with him driving went a little quicker as well but not sure. I'll update after the weekend. Hopefully I get in touch with Spooner and get the right numbers for Wade's other truck.
Noreaster
2,910
Cape Cod,MA
I didnt even look at the list, the name didnt ring a bell
Subman
Old Geezer
Jun 27, 2008
3,233
80
1/4 mile 10 second or quicker Duramax powered list: weight, type, tranny (if not an Allison) and tuner.
1.Banks Rail 7.170 @ 181.08 (4-30-09) - 2290 lbs, Liberty XT5/Molinari Clutch - BANKS
2.NGM Diesel 7.44 @ 187.55 (6-1-13) - 2800 lbs, turbo400 - Johnboy
3.J.Dean's Dragster 7.64 (6-8-13) @ 170.41 (10-13-12) - 2100 lbs, LBZ, powerglide - Stingpuller.
4.Banks Sidewinder Type-D 7.723 @ 179.23 (3-29-08) - Liberty XT5/Bruno - BANKS
5.NX dragster 7.829 @ 172.08 (6-11-11) - LBZ, Powerglide - Johnboy
6.Dirtymax 8.63 (6-16-12) @ 158.23 (5-19-12) - 3268 lbs, LB7, Lenco - ATP
7.NX Mustang 9.216 @ 154.5 (9-18-10) 3600 lbs, LB7, 4L80 - Johnboy
8.N20 Dmax 9.24 @ 151.6 (10-20-13) 5900 lbs - LB7, Duraflite - TTS
9.Max'd Out 9.360 (10-15-11) @ 149.13 (7-21-12) - 6100 lbs, LB7, Duraflite - ATP
10.bcdeutch731 9.432 @ 148.36 (10-27-12) - 4600 lbs, LLY - Mark at DP
11.Overkill 9.50 (6-23-12) @ 153.30 (7-29-13) - LB7 - Dmitri
12.J&R Auto GMC 9.570 @ 144.76 (8-11-12) - 5950 lbs, LB7, stroker, Duraflite, J & R
13.Mad Max/Hell Camino 9.68 @ 149.1 (8-10-13) -3600 Lbs, LBZ, duraflite,
14.Dallas@Suncoast 9.778 (6-11-11) @ 139.33 (5-18-12) - 6300 Lbs, LBZ, Duraflite
15.Rick Fletes/RPM MotorSports 9.78 (8-17-13) @ 142.4 (6-29-13) - 4530 lbs, LBZ Chevelle, XP-5 PG -ATP
16.Extreme Prejudice 9.87 (7-10-10) @ 146.13 (5-15-10) - LB7 - EPR
17.Orange Crush 9.875 @ 139.41 -(9-25-07) - LB7 - TTS
18.Mika 9.897 (8-29-10) @ 138.70 (8-14-10) - 7160 lbs, LB7, Duraflite - BOBO
19.Camomax 9.91 (2-25-12) @ 139.36 (11-19-11) - 6150 lbs LB7 - Duraflite, ATP
20.Duramini2001 9.994 (8-13-11) @ 138.566 (5-15-10) - 6900 lbs, LB7 - Dmitri
21.Misery 10.127 @ 135.74 (10-13-12) - 6000 lbs, LB7 - ATP
22.estelly 10.13 (5-18-12), 140.05 (4-15-12)- 6140 lbs, LMM - Power Performance
23.Jim Jones 10.148 @ 140.52 (10-13-12) - 6150 lbs, LB7 - ATP
24.OSUBeaver 10.184 (8-13-11) @ 134.59 (5-21-11) -5997 lbs, LB7, Duraflite - ATP
25.MorePower 10.271 @ 133.39 (7-13-13) 6820 lbs, LB7, DHD/Danville
26.NolanW 10.285 @ 133.15 (8-11-12) - Duraflite - ATP
27.Sweetdiesel 10.286 @ 144.09 (9-3-10) - 5700 lbs, LB7 - Simon
28.cafryer 10.298 @ 138.16 (8-28-13) - 6500 lbs, LB7 - EPR
29.Custom Auto shop truck 10.34 @ 140 (8-25-12) - LB7 - Custom Auto
30.Nasty Girl 10.355 @ 131.11 (7-13-08) - LB7 - MOONSHINE
31.DPS Prostock 10.377 @ 134.94 (10-13-12) -3100 lbs, LBZ - powerglide - Mark@Danville
32.BadDmax 10.438 @ 132.31 (7-10-09) - LB7 - MOONSHINE
33.W Minter 10.449 @ 128.88 (4-14-13) - ATP
34.MaxPowerLB7 10.47 @ 132.0 (3-11-11) - 6460 lbs, LB7 -Trent
35.Stingpuller 10.47 @ 131.75 (7-18-09) - 6000lbs, LBZ - Stingpuller
36.Alligator Performance 10.490 @ 132.78 (10-27-13) LBZ - PPEI
37.UDP 10.506 @ 137.71 (6-1-12) 6700 lbs, LB7 - UDP-mike
38.Casper 10.59 @ 128 (10-26-07) - 6420 lbs, LLY - McRat
39.White Out 10.703 @ 130.39 (8-27-10) - 6650 lbs, LBZ - ATP
40.Rhall 10.72 @ 128.0 (8-15-09) - LB7 - ATP
41.02Bigstrokin 10.732 @ 129.59 (9-8-10) - LB7 - MOONSHINE
42.Othrgrl 10.74 @ 135.94 (6-19-10) -6800 lbs, LLY - DA
43.straightpiperoar 10.78 @ 127.37 (6-15-12) - LBZ - ATP
44.Big Bird 10.82 (10-10-10) @ 129 (8-14-10) - 7200 lbs, LB7
45.Sickdiesel 10.825 @ 126.24 (6-22-13) - 6350 lbs, LBZ - ATP
46.NLDP 10.85 @ 123.35 (6-24-06) - LB7 - TTS
47.Bluessmax 10.878 @ 128.31 (7-21-12) - 5650 lbs, LBZ - 2x4 - Power Performance
48.Maxpower91 [email protected] (10-27 -12) - 6900 lbs, LB7- Duramaxtuner
49.White Lightning 10.96(5-18-13) @ 127.76 (6-8-13) - 5850 lbs, LBZ- Mark
50.J&R Auto Chev 10.973 (8-14-10) @ 126.15 - J&R
51.Utahski 10.979 @ 125.55 (10-5-12) 6900 lbs, LLY - EPR
MarkBroviak
DMax Junkie
2,141
499
Danville Indiana
Brett Deutsch gets new personal best today!
Brett is down in Florida testing transmissions and so far so good as he got a new personal best of [email protected]! Hopefully tomorrow he gets an even better pass out of it! This trany issue has been a 2-year project and it is nice to finally see some light at the end of the tunnel, Congrats Brett!:thumb:
bcdeutsch731
619
13
41
Illinois
That's awesome... Is it still running a Ford transmission?
Thanks guys. Yes I'm still using the 4R100. I have been having nothing but problems with the torque converter this year. I have a prototype converter in now and it looks promising
You can go to my Facebook page and see the videos
Deutsch's 1969 c10
