1/4 mile discussion and time slips post here!
MarkBroviak
DMax Junkie
2,151
549
Danville Indiana
Update for #88 Ryan Pini
Hey guys! Soooo Ryan decided to take the ZF6 out and put a Limitless Diesel Allison in his now even lower weight truck to see what it would do. First time to the track with the new setup still running my 72mmvgt in the valley with a pair of S475's feeding it on a single Exergy14mmcp3 and big sticks it knocked almost a second off his time with a horrible 60ft leaving at 4psi! Very happy with the results and once it is all dialed in it is going really make some noise! Here is the updated info for the pass it made and the slips from the other night. If you have facebook the videos are on his page and mine along with the Danville Performance page- https://www.facebook.com/danvilleperformance/ Thanks guys!
Date 8-24-19
Ryan Pini(Currently #88 on the list)
4360lbs LLY/Allison
[email protected] fastest mph was 150.9mph.
2,059
Updated.
1. NGM Diesel Dragster - 6.532 (6/23/18) @ 200.77 (6/10/17) - 2500 lbs, Turbo 400 - NGM Diesel
2. Banks Dragster - 7.170 @ 181.08 (4/30/09) - 2290 lbs, Liberty XT5/Molinari Clutch - BANKS
3. NGM Diesel Prostock - 7.44 @ 187.55 (6/1/13) - 2800 lbs, Turbo 400 - Johnboy
4. Batmobile prostock - 7.469 @ 186.26 (8/6/16) - 2700 lbs, LBZ, Bruno/Lenco - Vollmer
5. J.Dean's Dragster - 7.64 (6/8/13) @ 170.41 (10/13/12) - 2100 lbs, LBZ, powerglide - J. Dean
6. Banks Sidewinder Type-D Prostock - 7.723 @ 179.23 (3/29/08) - Liberty XT5/Bruno - BANKS
7. NX dragster - 7.829 @ 172.08 (6/11/11) - LBZ, Powerglide - Johnboy
8. John Sleath (UK) S-10 Prostock - 8.3664 @ 167.30 (10/31/15) - 3350 lbs, LB7, 4L80E - J. Sleath
9. bcdeutch731 C-10 - 8.395 @ 168.13 (9/22/16) - 4610 lbs, LLY, T-400, 2wd - Mark Broviak
10. Comp461 dragster - 8.508 @ 161.05 (10/4/14) - 1965 lbs, Powerglide/Gearvendors - C. Byden
11. Dirtymax Prostock - 8.63 (6/16/12) @ 158.23 (5/19/12) - 3268 lbs, LB7, Lenco - ATP
12. RPM Motorsports 73 Nova - 8.640 @ 166.17 (7/23/16) - 3460 lbs, LBZ, XP-5 Powerglide - ATP
13. Trippplemax #1, Ill Tempered - 8.89 @ 158.28 (5/4/18) - 6005 lbs, LBZ Stroker, Duraflite - C. Buhidar
14. Mike Graves Prostreet - 9.068 @ 161.19 (7/16/17) - 4520 lbs, LBZ, Allison - Mark Broviak, Evan Drosehn
15. NX Mustang - 9.216 @ 154.5 (9/18/10) - 3600 lbs, LB7, 4L80 - Johnboy
16. N20 Dmax - 9.24 @ 151.6 (10/20/13) - 5900 lbs, LB7, Duraflite - TTS
17. J Hyatt - 9.246 @ 156.46 (5/8/18) - 6300 lbs, LB7 - Ridgerunner
18. Industrial Injection shop truck - 9.28 (12/2/16) @ 154.99 (8/22/15) - 6040 lbs, LB7, Duraflite - Starlite
19. Max'd Out - 9.360 (10/15/11) @ 154.40 (5/5/16) - 6050 lbs, LBZ, Duraflite - ATP
20. K Douglas C-10 - 9.393 @ 147.46 (10/4/14) - 3100 lbs, LBZ, 2wd - G&J
21. Trippplemax #2, Road Rage - 9.459 @ 146.45 (8/8/15) - 5950 lbs, LBZ stroker, Duraflite - C. Buhidar
22. Overkill - 9.50 (6/23/12) @ 153.30 (7/29/13) - 5950 lbs, LB7 - Dmitri Millard
23. Mike Graves CrewCab - 9.555 @ 149.50 (4/22/17) - 6850 lbs, LB7, Allison - Mark Broviak, Evan Drosehn
24. Adam Hull - 9.583 @ 143.78 (7/8/18) - 5500 lbs, LLY, Allison, Mark Broviak
25. Meshanic 1/2 ton - 9.6168 @ 159.12 (12/17/16) - 5100 lbs, LBZ - Meshanic
26. Merchant's Sandrail - 9.62 @ 138.90 (6/27/15) - 2000 lbs, LBZ - Duramax Tuner
27. SmoknDmax05 - 9.655 @ 140.23 (5/7/16) - 5750 lbs, LLY, Duraflite - Fleece
28. SKTruckService - 9.668 @ 146.58 (6/28/18) - 5908 lbs, LB7 - Steve King
29. Mad Max/Hell Camino Prostock - 9.68 @ 149.1 (8/10/13) - 3600 Lbs, LBZ, Duraflite - ATP
30. Tony Burkhard/DHD - 9.726 @ 140.32 (7/29/18) - 5500 lbs, LBZ - Mark Broviak
31. Ne-max - 9.736 @ 143.54 (5/6/18) - 5950 lbs, LBZ - Mark Broviak
32. cafryer - 9.769 @ 145.02 (8/16/14) - 6500 lbs, LB7, Duraflite - Starlite
33. Dallas@Suncoast - 9.778 (6/11/11) @ 139.33 (5/18/12) - 6300 Lbs, LBZ, Duraflite
34. Rick Fletes Chevelle - 9.78 (8/17/13) @ 142.4 (6/29/13) - 4530 lbs, LBZ, XP-5 Powerglide - ATP
35. JKlennon - 9.802 @ 139.53 (5/1/19) - 5100 lbs, LBZ - Mark Broviak
36. RayRoss42 - 9.843 @ 138.33 (6/2/18) - 5550 lbs, LBZ - C Budihar
37. Extreme Prejudice - 9.87 (7/10/10) @ 146.13 (5/15/10) - LB7 - EPR
38. Orange Crush - 9.875 @ 139.41 (9/25/07) - LB7, 2wd - TTS
39. Ryan Pini - 9.883 @ 150.97 (8/24/19) - 4360 lbs, LLY - Mark Broviak
40. Dmax02 (Alex) - 9.893 @ 139.62 (6/10/16) - 6160 lbs, LLY - Mark Broviak
41. Mika (FIN) - 9.897 (8/29/10) @ 138.70 (8/14/10) - 7160 lbs, LB7, Duraflite - BOBO
42. dmaxdrid - 9.899 @ 143.36 (1/20//19) - 6700 lbs, LBZ, Allison - All in Truck Performance
43. Camomax - 9.91 (2/25/12) @ 139.36 (11/19/11) - 6150 lbs, LB7, Duraflite - ATP
44. IBDMAX'IN "Skeeter" - 9.924 @ 145.23 (6/4/16) - 6280 lbs, LB7, 2wd - Wade Boyd DDD
45. Dan PPE - 9.947 @ 142.04 (11/1/14) - 6200 lbs, LLY - PPE
46. Prostreeter600 - 9.978 @ 136.39 (11/11/16) - 6000 lbs, LBZ - Mark Broviak
47. Duramini2001 - 9.994 (8/13/11) @ 138.566 (5/15/10) - 6700 lbs, LB7 - Dmitri Millard
48. Duramax Tuner - 9.995 @ 138.89 (10/8/15) - 5500 lbs, LB7 - Duramax Tuner
49. Misery - 10.01 @ 144.52 (10/4/14) - 6000 lbs, LB7 - PPE
50. DBreschLB7 - 10.028 @ 135.40 (6/20/19) - 5700 bs, LB7 - HTPerf
51. Zack Fuller - 10.039 @ 139.30 (4/21/17) - 7600 lbs, LLY - Starlite
52. MissMax - 10.098 @ 141.45 (5/4/18) - 6450 lbs, LB7 - ATP
53. THduramax - 10.111 @ 136.36 (7/24/16) - 6000 lbs, LBZ, Duraflite - Fleece
54. Mike Maas - 10.118 @ 135.44 (6/8/19) - 6000 lbs, LB7 - Mark Broviak
55. Harbin_22 - 10.12 @ 138.12 (05/01/18) - 6860 lbs, LMM - Mark Broviak
56. estelly - 10.13 (5/18/12) @ 140.05 (4/15/12) - 6140 lbs, LMM - PPEI
57. Jim Jones - 10.148 @ 140.52 (10/13/12) - 6150 lbs, LB7 - ATP
58. OSUBeaver - 10.184 (8/13/11) @ 134.59 (5/21/11) - 5997 lbs, LB7, Duraflite - ATP
59. White Lightning - 10.242 @ 140.11 (6/10/17) - 5850 lbs, LBZ - Mark Broviak
60. MoorePower - 10.271 @ 133.39 (7/13/13) - 6820 lbs, LB7 - Mark Broviak
61. TDS Miami Colorado - 10.281 @ 137.72 (4/25/15) - 4550 lbs, LBZ - Duramax Tuner
62. NolanW - 10.285 @ 133.15 (8/11/12) - Duraflite - ATP
63. Sweetdiesel - 10.286 @ 144.09 (9/3/10) - 5700 lbs, LB7 - Simon
64. Coker6365 - 10.289 @ 135.79 (8/17/18) - 6400 lbs, LBZ - Josh Harris
65. Boosted_LBZ - 10.296 @ 135.71 (5/17/17) - 6380 lbs, LBZ - ATP
66. Custom Auto shop truck - 10.34 @ 140 (8/25/12) - LB7 - Custom Auto
67. Nasty Girl - 10.355 @ 131.11 (7/13/08) - LB7 - Ridgerunner
68. Sickdiesel - 10.429 @ 134.00 (4/6/14) - 6450 lbs, LBZ - ATP
69. IOWA_LLY - 10.436 @ 131.38 (9/24/17) - 6865 lbs, LLY - Hynick Perf
70. BadDmax - 10.438 @ 132.31 (7/10/09) - LB7 - Ridgerunner
71. Dave Martin - 10.439 @ 132.70 (5/5/18) - 6885 lbs, LBZ - Mark Broviak
72. JoeGorby - 10.461 @ 134.53 (11/4/16) - 6360 lbs, LBZ - Blackout Perf
73. MaxPowerLB7 - 10.47 @ 132.0 (3/11/11) - 6460 lbs, LB7 - EPR
74. Stingpuller - 10.47 @ 131.75 (7/18/09) - 6000 lbs, LBZ - J. Dean
75. Justin Duffy - 10.475 @ 128.10 (6/23/19) - 6250 lbs, LLY - UDT
76. Alligator Performance - 10.490 @ 132.78 (10/27/13) - LBZ - PPEI
77. Diesel Addiction Shop Truck - 10.490 @ 122.98 (10/25/17) - LBZ - Diesel Addiction
78. UDP - 10.506 @ 137.71 (6/1/12) - 6700 lbs, LB7 - UDP Mike
79. Trojan366 - 10.522 @ 132.62 (9/13/14) - 6860 lbs, LLY - Mark Broviak
80. BCatmull - 10.550 @ 133.66 (8/29/16) - LLY - RidgeRunner
81. Blake Crenshaw - 10.570 @ 127.59 (8/23/19) - 6250 lbs, LB7 - UDT
82. Hondarider552 - 10.578 @ 133.88 (4/6/14) - 5400 lbs, LB7 - PPEI
83. Casper - 10.59 @ 128 (10/26/07) - 6420 lbs, LLY - McRat
84. BLKLMM - 10.625 @ 134.34 (3/22/14) - 7000 lbs, LMM - PPEI
85. onebaddmaxx - 10.628 @ 133.05 (4/17/19) - 4650 lbs, LLY - Mark Broviak
86. David Benjamin - 10.642 @ 128.09 (6/19/17) - 6900 lbs, LBZ - Mark Broviak
87. dmax02 (Zach) - 10.661 @ 127.58 (8/16/17) - 6900 lbs, LB7 - Mark Broviak
88. Brandon Serpa - 10.662 @ 125.09 (6/29/17) - 5900 lbs, LMM - Mark Broviak
89. White Devil - 10.672 @ 132.62 (4/24/15) - LLY - CaptPhil
90. 2themax2 - 10.687 @ 129.06 (5/21/16) - 6700lbs, LMM - Starlite
91. Jonathan Parrish - 10.699 @ 127.35 (5/18/18) - 6700 lbs, LLY - Mark Broviak
92. White Out - 10.703 @ 130.39 (8/27/10) - 6650 lbs, LBZ - ATP
93. IBDMAX'IN "Blue Angel" - 10.71 @ 132.3 (7/10/10) - LB7 - Wade Boyd DDD
94. Rhall - 10.72 @ 128.0 (8/15/09) - LB7 - ATP
95. Mike Diesel - 10.725 @ 134.97 (4/23/16) - 7000 lbs, LLY - Starlite
96. 02Bigstrokin - 10.732 @ 129.59 (9/8/10) - LB7 - RidgeRunner
97. Othrgrl - 10.74 @ 135.94 (6/19/10) - 6800 lbs, LLY - Diesel Addiction
98. 2DMAX - 10.768 @ 132.02 (6/17/16) - 6800 lbs, LBZ - Mark Broviak
99. Jpowel29 - 10.778 @ 125.56 (10/25/14) - LBZ- JPowel
100. straightpiperoar - 10.78 @ 127.37 (6/15/12) - LBZ - ATP
101. Dylan Lucy - 10.782 @ 127.47 (5/4/18) - 6700 lbs, LLY - UDT
102. Vsouth - 10.787 @ 131.08 (10/10/17) - 7500 lbs- LBZ - ATP
103. Kolten Kibler - 10.790 @ 126.79 (11/18/18) - 6050 lbs, LB7 - UDT
104. Adam - 10.817 @ 135.11 (7/24/19) - 8000 lbs, LML - UDT
105. Big Bird - 10.82 (10/10/10) @ 129 (8/14/10) - 7200 lbs, LB7
106. Maine04max - 10.825 @ 128.73 (10/3/15) - 6920 lbs, LB7 - Maine04max
107. Dante Delaney - 10.829 @ 125.08 (5/22/19) - 6800 lbs, LMM - UDT
108. NLDP - 10.85 @ 123.35 (6/24/06) - 6300 lbs, LB7 - TTS
109. TNG Dumpster Van - 10.868 @ 124.82 (4/12/14) - 5320 lbs, LBZ, 4L85E, 2wd - JoshHarris
110. Troy Tyler - 10.870 @ 124.24 (5/8/19) - 7000 lbs, LBZ - Mark Broviak
111. Bluessmax - 10.878 @ 128.31 (7/21/12) - 5650 lbs, LBZ, 2wd - PPEI
112. Trace Wilks - 10.885 @ 128.73 (8/25/18) - 6700 lbs, LBZ - UDT
113. Dmax497 - 10.887 @ 126.93 (8/12/16) - LBZ - RidgeRunner
114. Ryan Esposito - 10.889 @ 126.30 (5/21/19) - 6600 lbs, LMM - Mark Broviak
115. Scott Mathews - 10.902 @ 127.44 (11/7/15) - 6800 lbs, LLY - Diesel Addiction
116. Joshua Higman - 10.902 @ 124.44 (10/27/18) - 6800 lbs, LBZ - Mark Broviak
117. Jake Banman - 10.910 @ 125.73 (12/6/18) - 5350 lbs, LBZ - UDT
118. ZF>Allison (Jesse) - 10.912 @ 130.27 (4/20/18) - 5000 lbs, LLY, ZF6 - Mark Broviak
119. Jeff Wendorff - 10.932 @ 129.11 (6/12/19) - 6800 lbs, LBZ - Mark Broviak
120. TNG Shop Truck - 10.933 @ 128.64 (8/3/18) - 5940 lbs, LMM, 2wd - Josh Harris
121. Maxpower91 - 10.937 @ 127.16 (10/27/12) - 6900 lbs, LB7 - Duramax Tuner
122. gmduramax - 10.939 @ 126.22 (1/3/15) - 7060 lbs, LMM - PPEI
123. Justin Serpa - 10.941 @ 126.12 (3/13/19) - 6800 lbs, LMM - Mark Broviak
124. Eric Merchant - 10.952 @ 122 (5/4/18) -6200 lbs, LBZ - Duramax Tuner
125. WisconsinHick1 - 10.955 @ 128.37 (7/30/16) - 5700 lbs, LB7, 2wd - WisconsinHick1
126. J&R Auto Chev - 10.973 @ 126.15 (8/14/10) - J&R
127. Utahski - 10.979 @ 125.55 (10/5/12) - 6900 lbs, LLY - EPR
128. C. Mauch - 10.979 @ 125.41 (10/28/17) - 6700 lbs, LB7 - Duramax Tuner
129. BHoward6.6 - 10.984 @ 124.88 (8/27/16) - 7000 lbs, LBZ - Mark Broviak
Congrats guys. :)
Evan@InglewoodTrans
yerp
3,118
66
Western MA
Date 8-24-19
4360lbs LLY/Allison
With no lockup so it’s safe to say that truck has the potential to set some records.
MarkBroviak
DMax Junkie
2,151
549
Danville Indiana
Ryan Esposito has improved his time!
#114 on the list Ryan Esposito has improved his time yesterday at a test and tune event! Congrats Ryan!
MarkBroviak
DMax Junkie
2,151
549
Danville Indiana
New one for the list!
Malachi Messenger decided to put slicks on his sled puller and send it down the drag strip and it went rather quickly! His truck is an LLY/Allison combo with a single S48x. I tune it and it weighs 6800lbs. Thanks guys!:hug:
