I have an 09 lmm and it has the a50 tcm in it. U can't tune the a50 tcm so I was wondering if there is any way I can be able to run an a40 tcm so I will be able to tune it? I pull and want to be able to delete gears for pulling so I can get off of the line faster without defueling. Can you swap out tcm s and reprogram it to make it work? Or swap an 08 ECM and tcm to make it work? Or is the wiring harness different for the a50 tcm and I would have to swap the wiring harness out?
