LMM: 09 silverado CC LB duramax, under bed findings.. fuel sender?
pitbull14218
Apr 25, 2018
67
So im changing my bed, inspecting the fuel sending unit, its definitely rusty, so while i have easy access i would like to change it. how do i know which one i need, seems like there are a bunch of different ones on rockauto.
Also, found this piece of metal, i dont inow where its from. seems like it was from the frame?
torqued2dmax
646
Brookville, PA
We ran your finger print through NCIS you may want to go into hiding ! That is a lot of rust, I was wondering if anyone ever used that brush on rust remover that just washes off with water and if so the results !
pitbull14218
Apr 25, 2018
67
Drop the tank and clean behind it also
That’s a bed bolt but spacer. Goes on the bottom of the bed.
Its actually got like a full tank of fuel, and its not on the road, so I won't be able to drop the tank right now unfortunately.
2,010
Pretty sure if goes on the first bolt just behind the cab. We arent there, though. You'll figure it out.
pitbull14218
Apr 25, 2018
67
So the bed bolt spacer I only found one of them, not sure how many I need.
Also if I order the above fuel sending unit from Rock auto, does it come with the gasket and clip/ring holder or do I need to buy those as well?
ikeG
Oughta Know Better
Apr 19, 2011
2,474
152
Western PA
www.facebook.com
I just replaced mine, it was rusted completely through. I got the sending unit as well as a new lock ring from Napa. The unit came with the o ring.
Sent from my XT1585 using Tapatalk
pitbull14218
Apr 25, 2018
67
I appreciate the help I got from the members here that helped me. But this information isn't performance related, so if mods can please delete the entire thread.
Thanks!
