You have use a good scanner or tech 2 to make the encoder motor relearn
Have a C0569 code?
1. Turn ignition switch to the Accessory position.
2. Place 4WD switch to "2 high"
3. Turn switch past "4 low" to neutral and hold for 30 seconds
4. An audible noise from the motor indicates the learn procedure was completed.
