LMM: 07 LMM Lost oil pressure
1chevy02
Jun 23, 2009
504
There is a guy down here whos ccsb 4x4 07 LMM, with 37k on it, lost oil pressure. He had a tuner on it and gm won't warranty it and he can't afford to fix it. He says he got it shut down as soon as it lost pressure and it wasn't knocking or anything. Just wondering what it might be worth or how major the damage is.
1chevy02
Jun 23, 2009
504
I was wondering that too but, he says gm hooked up a manual guage? He has it partially tore down, then he gave up. I was wondering about getting an oil sample and just seeing what it said. I wish I could crank it over and see what it did. Where would be the best place to hook up a manual guage? Worse case scenario......New crank and bearings?
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
39
Locust, NC
OHM the pressure sensor out first. Then you could hook up a gauge on the driver side of the block in the main oil galley. The thread pitch should be a M14x1.5 in the oil galley plugs.
1chevy02
Jun 23, 2009
504
Where is the oil pump on these motors? I guess it has to come out to check the oil pump? How is it driven?
1chevy02
Jun 23, 2009
504
PPE Extreme. Yes he took if off but, they checked his calibrations and found out he had been tuned. He had guages and all though.
Bustedknuckles
Honey Badger
Sep 25, 2010
1,308
33
Hagerstown MD
The dealer needs to prove the modification caused the failure. An electronic programmer will not cause a loss of mechanical oil pressure. No way no how. I would be going back to the dealer, perhaps with a lawyer.
Sent from my Evo while driving.
1chevy02
Jun 23, 2009
504
I think he tried a few things. Its been sitting for almost 2 years now. Im just wondering if its something that I want to get into or not.
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
PM me if he decides hes looking for a drop in replacement LMM motor.
:thumb:
EDIT: Just saw your screen name...I think I responded to you on SWCR....
If he had a internal part failure, sure as shit a tuner can cause it. PPE Hot +2, you know before you flash that tune in that you better be ready to pay to play. Says it in the manual now about ANY tuner.
Bustedknuckles
Honey Badger
Sep 25, 2010
1,308
33
Hagerstown MD
:thumb:
Well looks like he waited too long anyway. I know souping your truck up causes problems, blown headgaskets, trans and rearend problems, bent rods, cracked or melted pistons etc., sure, but no oil pressure????
1chevy02
Jun 23, 2009
504
I guess if I cranked it over and the front balancer doesn't move it also wouldn't have any oil psi.
1chevy02
Jun 23, 2009
504
Ok I went and pulled the oil sender and glow plugs today. I cranked it over and no oil:(
I pulled an oil sample. I'm going to see what it says. I was thinking about pulling the front timing cover and see if the oil pump look good:confused: Any Ideas?
Bustedknuckles
Honey Badger
Sep 25, 2010
1,308
33
Hagerstown MD
Why did you pull the glow plugs? I would pull the engine and get it on a stand so you can really see what's going on since you obviously don't have oil pressure. Are you looking to buy the truck or what's the scoop with it sitting so long before looking at it?
