not sure if this is in the right place or not. i have an 06 lbz that has been mysteriously using coolant with no external signs of a leak for the past year months roughly. seems to only do it in the cold months though. the other day it started pushing it out the degas bottle. it takes a long time to come up to temp. once up to temp it is fine all day. never over heats or looses heat from heater output. tested for blown head gasket with co2 tester and passed showing no head gasket problem. tried bypassing the coolant to the egr cooler and still same problem. was going to try t/stats next. also read a little about oil cooler as possible cause. any help would be greatly appreciated.
truck is stock. only has air raid cold air intake and 4" mbrp exhaust for now. still waxes cummins and p strokes though lol
