LLY: 05 lly blowing coolant outta overflow
WVRigrat05
Wound for sound
Jan 1, 2011
3,081
French Creek, West Virginia
Run the truck up to operating temp. (hose will be very hard, can't be squeezed together) Let the truck cool completely, usually over night (hose should be fairly soft, easily squeezed together). If it's soft, I would put a new cap on it and see how it acts.
For what it's worth my LLY went 95K before I lost a head gasket. It's had double stacked tunes in it's early days and a 600+ rwhp tune for the last 5 years... My head gaskets owed me nothing.
I owned mine a month and it was new, lol, but the 60k I ran it with them oooped made up for it
Parker_
I'm a torque addict !!
May 13, 2014
244
Blythe ca
So I did this and this am it was fine , soft no issues . So yeah just get a new radiator cap ?
As in the cap on the overflow right ?
Parker_
May 13, 2014
244
Blythe ca
Yep overflow cap. I would try that first...
Prepare to laugh at me : overflow cap was the problem . Also had a pinched heater line going to the core no clue how that happend . Feel shameful for even writing this thanks for your help guys
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,238
382
At Da Beach
All the Lily's I've seen have weird problems that you think are fixed. Everyone has had gaskets, eventually it will leak from the passengers side head at the back near the fire wall...
Burn Down
Sep 14, 2008
7,092
Boise Idaho
No laughing here, glad it was something simple.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Are you talking about the heater core.? I came pretty close to breaking the plastic connector of the hose while installing my downpipe.
Parker_
May 13, 2014
244
Blythe ca
Yup ! It actually broke the fitting when I went to replace it . So no heater for me , and now I got a code glow plug control module as well . I know there not related just saying . Hoping it starts gonna be 30 degrees at 3 am
Parker_
May 13, 2014
244
Blythe ca
Thanks gonna keep a special savings going because after this scare and they many google search articles it's def going to happen . Some guys chimed in here at like 40k 90k and 200k miles so it seems just the luck of the draw I guess
2,010
Simple, cheap solutions are the best, no matter how you find them. Glad for you. :thumb:
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Found one on my truck a couple weeks after replacing the alternator with a higher at idle output amperage. The wires coming out of the alternator where it disappears into the larger harness were rubbed through, no charging issues just doing my every 2 month inspection and started pulling some loose tape when I found them...
Parker_
May 13, 2014
244
Blythe ca
Nice
Tobin LLY
Jun 28, 2016
9
LLY Blowing Coolant Out!
So this seems to be a common issue on the LLY... The question is; WHY?
My '05 is doing it now at 154,000 miles!
Is it always the same side that goes? and which side is it?
Who has an upgrade gasket so it does not happen again?
Why is there no coolant mixing with the oil?
Someone mentioned Head Studs. Do I need to replace them as well? The truck is stock...
Can I do just the Head Gasket or is it necessary to do all the others I see in various kits?
Any one have a recommended procedure for the gasket replacement?
Thank for the help!
clrussell
pro-procrastinator
Sep 23, 2013
5,948
409
Thank for the help!
Google Lly head gasket replacement.. the new gaskets from gm are good, the new head bolts are plenty for a stock or lightly modded truck.
