let the pressure out when its cool, top the coolant off. drive it 30-40 miles and let it get hot, park it and checl the top radiator hose in the morning and see if its firm ike a tennis ball. if so pretty good chance your gaskets are done. time for studs
It will show it's running cool because it's shoving coolant out of the system giving a false reading, I can assure you it's plenty hot. Time for some head gaskets.
Time for head gaskets. Thermostats will not cause it to make it overflow.
Well that sucks trucksnonly got a 145k on it . I haven't google searched it but I'm assuming a couple thousand ?
Depends. Going to do the work yourself or have a shop do it?
I did exactly as stated above and to my knowledge it doesn't feel like the upper rad hose is stiff like a tennis ball . It isn't soft either tho but I can squeeze it without trying that hard at all
And if only one cylinder is blown (good thing) it won't be super hard, just hard enough to not squeeze the hose together and push coolant out.
I did mine myself at 19 y.o. With no prior diesel experience in my yard after work, I had 4200 bucks in it with **** ups and extra performance parts.
Put the hood in service mode. If you look at the hinges there's another set of holes, it will allow the hood to be straight up and down. Way easier and can do it yourself. That's a personal preference, myself, I'm not pulling the motor unless it's blown up.
Take a lot of pics, put bolts back where they went if you don't think you can separate correctly or are ADD like me.
Oh have to pull the pushrods and such but you only have to adjust the valves once, I usually set them all, spin the motor over a couple times and re-check them, you'd be surprised how often you miss one or one is a little loose.
