LLY: 05 Ex Cab-Short Box Rear Driveshaft Length
4,155
1,264
As the title states, looking for the overal length of the factory rear driveshaft on an extended cab short box truck.
My driveshaft decided to fold up last night pulling and I need to get one made up. I already ordered the LMM 1480 slip yoke and the GM 1480 pinion yoke with damper.
Any help is appreciated.
4,155
1,264
I have one in the shop I measure tomorrow morning for you Brad if you don't get it before.
If you could that would be much appreciated!
59.5in IIRC. I'd measure mine but it's raining out :D
Thanks! I’d measure mine but it’s in 2 pieces. Plus it also banged the exhaust up pretty good. Time for more flex pipe I guess. Nothing about my truck is a show truck, I set out to build a sleeper.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,492
472
Central OH
I put a 1480 setup in it, parts were supposed to be from a zf6 truck.
I suppose the LMM could be different but I don't see why it would be.
4,155
1,264
Slip Yoke (PN: 22918657)
Rear Axle Yoke Kit (PN: 12471499; has seal/nut/washer)
Strap (PN: 15734903)
Bolt (PN: 15734903)
T-Case Output Seal (PN: 12478093)
Driveshaft is going to cost me ~$225 which includes 4"x0.083" tube, 2x weld in 1480 flanges, 2x rockwell high strength industrial joints, and a balance job. They claim the rockwell joint holds up better than the spicer in pure torsion testing but they also use the rockwells because they do alot of military shafts.
I will probably swap out the rockwells for Spicer lube for lifes (non-greasables) once I get it.
