Truck ran great, got up one morning started it and it was smoking white bad. Running rough and coughing a little thru the exhaust....I think I made the call too early to replace the injectors. I really didnt do any diag on it. So i tore it down. Put new sac00’s, delco c headgaskets, resealed all cups, rebuilt filter head. Everything visually looked ok as far as piston tops, valves, deck surfaces. Put it together and started it. Constant heavy white smoke , rough idle, acts like it doesnt want to clean out. I have only started it twice. So i go and do some checking, resistance is .6 on all 8. Compression is 270-320 across the board cold. Im lost. I just bought the truck, ran perfect for 2 days. It has a holley lift pump edge cts2 and exhaust thats it. Im not sure where to look anymore. All grounds are hooked up clean and tight. About to have it towed to a specialist.. any insight would be much appreciated
