03 lb7 oil in coolant
Wildhare54
Wildhare54
Aug 26, 2017
14
California
Did you have to do any machine work to the valves to make sure there was enough clearance to the Pistons or with a c gaskets enough to make up for it
torqued2dmax
646
Brookville, PA
Just a thought , if you have the extra $ , now would be the time to do a slight upgrade to the valve springs since you did say you were going into the turbo . Unless you have more will power than others to resist 100% overs an extra 10mm pump 250 hp EFI tune . Im sure you can resist so forget I said anything . LOL!
Wildhare54
Wildhare54
Aug 26, 2017
14
California
Well it's back together and running like a champ. About 22 hrs of work to get it all done. Could visibly see where the oil was bypassing the gasket. Had the heads surfaced and there grade c gaskets in it. While I was there it got a ppe down pipe, ppe boost increase valve, billet turbo wheel from Heath Diesel and a 3.5 inch intake horn. Loving the way the truck responds now.
