02 LB7 Trans De Fueling
dndj
Boost!
Apr 13, 2019
302
Oregon
Try out the link above, post #17, for the online version and see if that works
I think it was post #117 from the thread you referenced. I just grabbed your "LB7 & LLY Defuel Calculation experiment.xls" file from post #117 and I'm seeing the same error as RMJ_LB7 noted in post #13 in this thread. Using Excel 365.
The New TLIQ table is getting a bad reference from the "LB7 TLIQ B0741 Full Reverse" tab. For some reason, starting midway through row 470 (cell T470) on this sheet, all the array formulas are missing and there's just a {=#VALUE!}. However if I just copy down the array formulas from the last full good row 469 all the way to the bottom of the table, all seems to be well.
Hope this helps.
I was using the manual version as a way to learn the interactions between TBIQ, TLIQ and BT. It seems the magic here is to ensure a smooth transition when moving between TBIQ and TLIQ (torque limited) fueling regimes.
