ZF6 clutch line upgrade
CarolinaHD
969
NC
Anyone tried these -3an fittings from RAM Clutch? Part number RAM-78310.
https://www.summitracing.com/parts/ram-78310
Oem hose length is 59" tip to tip. Using this 60" line from nitrous outlet would be just about perfect and wouldn't require any extra work. Total cost is $100 from summitracing
https://www.summitracing.com/parts/nxo-00-20270
attachment.php
attachment.php
attachment.php
07keo02
Oct 5, 2011
399
Phoenix, AZ
I have a thread somewhere on dieselplace where I had a custom stainless line built with metal fittings. I also removed the drain back valves to see if there would be any better response/feel/engagement with my southbound dual disc. Didn't make much difference. There is a plastic piece in the pedal mount that flexes. Another member was duplicating this piece out of metal. I think you would see more results in addressing that.
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
I need to make a steel pedal, I don't even have the dash in the way I dont know what's stopping me lol, I kind of want to do a bigger stroke master cylinder so I don't have as far pedal travel when I stab my clutch.
07keo02
Oct 5, 2011
399
Phoenix, AZ
There is also a thread over on dieselplace where a guy was making steel pedals. Just browse the zf6 aftermarket thread page.
4,903
bigger bore MC will give the same affect as well.
either setup will require more leg effort though :D
CarolinaHD
969
NC
It was actually someone else's thread and I ended up posting the line in there. Also good info on how I set up mity vac bleeding as well. Doing this you can remove the check valves and get a bit better flow. Adam may still make the line I gave him specs on.
http://www.dieselplace.com/forum/57...2625-loss-clutch-pressure-other-issues-5.html
Nice thanks for the link, somehow I missed that thread in all my researching. Here's the post about the mityvac
http://www.dieselplace.com/forum/50...stom-adjustable-solid-steel-clutch-pedal.html
Jadetrost
Mar 25, 2024
3
Bronx, NY
