Old Fashion Days Pull "Fall Fleece Pull" Sept 3
paul06d-max
Nov 18, 2010
On Sept 3 we will be haveing our annual sled pull in North Salem, IN
Classes will be the same as the spring pull 2.5, 2.6, 3.0
Hope to see everyone there....
I'll link the rules in soon...
Thanks Paul
carpenca
Dec 17, 2010
168
Old Fashioned Days "Fall Fleece Pull" Classes and Rules
1. Work Stock Class​
True 2.5” Inducer Bore NO CLIPPED WHEELS / NO BUSHINGS / NO
TAPERED COVERS
.200 MAX mwe Groove
No Hanging Weight Beyond Front Bumper (Ballast Permitted)
8000lb Maximum (With Driver)
26” Hitch Height
DOT Tires
No Dual pumps, no compressed gases or Power Adders of Any Kind
Diesel Fuel Only
Traction bars are allowed
Valid Registration and Proof of Insurance Required
Single Wheel Trucks Must Run Single Rear Tires, Factory Dual
Rear Trucks are Permitted to Run Dual Rear Wheels
2. Hot Street​
2.6” Inducer Bore
Minimum 1/8" Protrusion Into Bore
.200 MAX mwe Groove
Hanging Weights are permitted within 60” from axle CL
8000lb max (With Driver)
Driveshaft loops, u-joint shields and bump stops required
Dual pumps are permitted
No compressed gases of any kind
No Water/Meth
26” Hitch Height
DOT Tires
5. Super Street​
3.0” Inducer Bore
.250 MAX mwe Groove
8000lb max (with driver)
Water Injection Permitted No methanol
26” Hitch Height
DOT Tires
Caleb
carpenca
Dec 17, 2010
168
Puller registration starts at Noon. There will be 4wd Mod Gas class that will hook at 2:00 PM, and Diesels will start at 3:00 PM.
The Stock Diesel Class Rules:
-100% Stock Turbo
-Traction Bars Allowed
-1" Suspension Travel
-Valid Registration and Proof of Insurance
Caleb
carpenca
Dec 17, 2010
168
Dont let the rain Bother you fellas, Weve been poured on the last couple of times weve hooked, generally only results in a delay, weve got a tip top track crew to keep the track in good shape.
Caleb
carpenca
Dec 17, 2010
168
Schedule of Events:
- Puller Registration Opens - 12:00 PM
- 4x4 Altered Stock Gas Class - 2:00 PM
- Stock Turbo Diesel Class - 3:00 PM
- 2.5" Work Stock
- 10,500lb Farm Tractors
- 2.6" Hot Street
- 12,000lb Farm Tractors
- 3.0" Super Street
- 13,000lb Farm Tractors
Caleb
rgullett83
1,608
Illinois
were gonna be pushin to get there by 2 your time, we will be pullin 2.6 class, is that gonna allow us enuff time?
rgullett83
1,608
Illinois
after two attempts in the 2.6 class, we didnt move the sled...... come to find out the ouput speed sensor came unplugged when the trans blanket got put back on the other night:rofl:
