The cooler is about a year old give or take. And I'm not sure I would imagine. My buddy put all new fluids in after the install. I will ask him.
2008 gmc sierra 2500 lmm
yeah id check for sure, and if not do it
They used to have heated washer fluid. GM recalled them and removed it because of fire hazard. The resistor wasn't big enough and would catch on fire.
The letter I got was the driver airbag said it would gain pressure and when or if it gets set off could send metal fragments into the drivers face causing a horrible death. Paraphrasing a bit lol but that's basically what mine said. Luckily I guess you could say my air bag got replaced last summer because of a idiot driver.Side note: they just recalled the passenger air bag about a month ago on 08's
Hahaha no kidding. Ya I got the letter recently. Which was shitty because like I said.last summer I had it deploy.in my face. Glad mine wasn't one of the bad ones.I removed mine because my horn didn't work and the connections were broke. Too many mantrums thrown while driving.
Makes me feel better now that I know I handled death and repaired my truck all Willy nilly
Had a dodge at one point and got the front end recall letter and it basically said a drag link or tierod will sheer off and you would have no steering.
So may be dumb but should I change the filters and fluid do a good cleaning soon since the trans is fresh built? Kind of.like a break in period fluid filter change?
its never all going to come out. the material will pack its self inbetween the fins very well, specially when everything is hot and the metal expands. it wouldnt hurt to pull the internal filter, split it and see how much junk is in there. until you change the radiator, you will always be getting stuff in that filter but thats why its there. you just dont want it plugging up
Well when I do my fuel filters and oil next I'll be changing my trams fluid amd.filters as well and inspect the internal filter real good. Until then I'll blow out the radiator and cooler real good. Might end up buying a new cooler. I had a lot of power running through it for a long time before the trans got built I'm sure it's caked. My trans guy told me this morning that he took more then adequate time cleaning out the lines and cooler.
